주요 콘텐츠로 건너뛰기
Mitsubishi Diamondpoint NXM76LCD Speaker Replacement
필요한 것
  1. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 1 단계, 이미지 3개 중 1개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 1 단계, 이미지 3개 중 2개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Removing the stand.: 1 단계, 이미지 3개 중 3개
    • Lift the black cover off.
    • Remove all 4 Phillips #2 screws.
  2. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the 5 screws: 2 단계, 이미지 1개 중 1개
    • Remove the two 24mm Phillips #2 screws.
    • Remove the three 8mm Phillips #2 screws.
  3. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 3 단계, 이미지 3개 중 1개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 3 단계, 이미지 3개 중 2개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the back panel: 3 단계, 이미지 3개 중 3개
    • Lift the back and pry the back off.
    • The panel is held in with clips on the side. It needs a lot of force the take it off.
  4. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: 4 단계, 이미지 2개 중 1개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the four screws: 4 단계, 이미지 2개 중 2개
    • Remove the four 5mm nut screws.
  5. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 5 단계, 이미지 2개 중 1개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the seven Phillips #1 screws.
  6. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: 6 단계, 이미지 2개 중 1개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement, Remove the front board: 6 단계, 이미지 2개 중 2개
    • Remove the three Phillips #2 screws.
    • Remove the two data/power cables.
    • Remove the two speaker cables.
  7. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 7 단계, 이미지 2개 중 1개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 7 단계, 이미지 2개 중 2개
    • Remove the Phillips #2 screws from the speaker(s).
  8. Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 8 단계, 이미지 3개 중 1개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 8 단계, 이미지 3개 중 2개 Mitsubishi Diamondpoint NXM76LCD Speaker Replacement: 8 단계, 이미지 3개 중 3개
    • Pull the speaker off the slots.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Padraic Hoselton
회원 가입일: 08/22/17
4,282 평판
안내서 12개를 작성함
Master Techs Master Techs 회원
Community
327 회원들
안내서 1,676개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 16
전체 시간: 150
