주요 콘텐츠로 건너뛰기
Mitsubishi Electric DD-6040 Power Button Replacement
필요한 것
  1. Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: 1 단계, 이미지 1/3 Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: 1 단계, 이미지 2/3 Mitsubishi Electric DD-6040 Power Button Replacement, Power Button: 1 단계, 이미지 3/3
    • Unplug your DVD player prior to working on the device.
    • Remove five 1.2 mm Phillips #1 screws to disassemble the DVD player.
  2. Mitsubishi Electric DD-6040 Power Button Replacement: 2 단계, 이미지 1/3 Mitsubishi Electric DD-6040 Power Button Replacement: 2 단계, 이미지 2/3 Mitsubishi Electric DD-6040 Power Button Replacement: 2 단계, 이미지 3/3
    • Once the screws are removed, slide back and remove the cover.
  3. Mitsubishi Electric DD-6040 Power Button Replacement: 3 단계, 이미지 1/3 Mitsubishi Electric DD-6040 Power Button Replacement: 3 단계, 이미지 2/3 Mitsubishi Electric DD-6040 Power Button Replacement: 3 단계, 이미지 3/3
    • Gently pull out the green circuit board.
    • Be very careful, as circuit boards can be quite fragile.
  4. Mitsubishi Electric DD-6040 Power Button Replacement: 4 단계, 이미지 1/2 Mitsubishi Electric DD-6040 Power Button Replacement: 4 단계, 이미지 2/2
    • Flip the DVD player over and pull up on the clip.
  5. Mitsubishi Electric DD-6040 Power Button Replacement: 5 단계, 이미지 1/3 Mitsubishi Electric DD-6040 Power Button Replacement: 5 단계, 이미지 2/3 Mitsubishi Electric DD-6040 Power Button Replacement: 5 단계, 이미지 3/3
    • Once the clip is unlatched disconnect the corner tabs.
    • Reorient and unlatch the tabs inside the device.
    • Remove the faceplate.
  6. Mitsubishi Electric DD-6040 Power Button Replacement: 6 단계, 이미지 1/3 Mitsubishi Electric DD-6040 Power Button Replacement: 6 단계, 이미지 2/3 Mitsubishi Electric DD-6040 Power Button Replacement: 6 단계, 이미지 3/3
    • Pull on the old power button to remove it.
  7. Mitsubishi Electric DD-6040 Power Button Replacement: 7 단계, 이미지 1/2 Mitsubishi Electric DD-6040 Power Button Replacement: 7 단계, 이미지 2/2
    • Adjust and push the new button into place.
결론
To reassemble your device, follow these steps in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Usha Alexis
회원 가입일: 01/12/20
199 평판
안내서 1개 작성함
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2020 회원
USFSM-STEWART-S20S1G1
23 회원들
안내서 27개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 334
