주요 콘텐츠로 건너뛰기
Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2)
필요한 것
  1. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Turn on the Ignition: 1 단계, 이미지 1개 중 1개
    • Turn the Ignition switch to the ACC or ON position.
    • Switch off the radio and CD player by py pressing on the PWR/VOL knob.
  2. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Enter Diagnostic Mode: 2 단계, 이미지 1개 중 1개
    • Press the following buttons in that order within sixty seconds from Step 1:
    • The 1 RPT button.
    • The button.
    • The button.
    • The 4 ⏩ button.
    • The display should now read DIAG MODE.
    • When an invalid button is pressed during diagnosis mode except the hands free-ECU update, the diagnosis mode will be cancelled, thus switching off the radio and CD player.
    • While in diagnosis mode, the sound input to the microphone unit is output directly through the speaker.
  3. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Navigate the Diagonstic Menu: 3 단계, 이미지 1개 중 1개
    • Turn the ♪/SEL knob clockwise to display HFM DIAG.
    • Press on the ♪/SEL knob to display HFM DIAG TOP.
  4. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Check the Parts Number: 4 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Check the Parts Number: 4 단계, 이미지 2개 중 2개
    • Turn the ♪/SEL knob clockwise twice to display the Parts Number.
    • The display should read something along the lines of PN XXXXXXXX.
    • We'll need this later when downloading the Firmware file.
  5. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Check the Software Version: 5 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Check the Software Version: 5 단계, 이미지 2개 중 2개
    • Turn the ♪/SEL knob clockwise twice to display the Software Version.
    • The display should read something along the lines of S/W XXXXXXX.
    • If the Version Number is 19.00.000 you already have the last available Firmware installed and don't need to do anything.
  6. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Download the Firmware: 6 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Download the Firmware: 6 단계, 이미지 2개 중 2개
  7. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Move the File: 7 단계, 이미지 1개 중 1개
    • The flash drive needs to be formatted to FAT32 and should not be larger than 16GB. Additionally the head unit can be a bit picky and might not accept all flash drives. If it can't read your flash drive, just try a different one.
    • Copy the update.package file to the root directory of the USB flash drive.
  8. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Insert the flash drive: 8 단계, 이미지 1개 중 1개
    • Insert the USB flash drive into one of the USB ports in your car.
    • You can usually find a USB port inside the center console or below the head unit.
  9. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Initiate the Update: 9 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Initiate the Update: 9 단계, 이미지 2개 중 2개
    • Re-enter the HFM DIAG-Section of the Diagonstic Menu by repeating the previous steps or pressing the 6 ↩ button while displaying the Version Number.
    • Initiate the Update by pressing on the ♪/SEL knob.
    • If the display reads NO FILE it means that it couldn't read your flash drive.
    • If the display reads HFM UPDATE it means that it found an update file on your flash drive, and will proceed in 3 seconds.
  10. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Enter the Security PIN: 10 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player, DY-1MU3R45-T and DY-1MU3R45-T-2), Enter the Security PIN: 10 단계, 이미지 2개 중 2개
    • When the display reads CODE_, enter the Security PIN using the number buttons.
    • If you don't have one set you can just enter 1234.
    • Perform the following steps to remove your Security PIN, if you have forgotten it:
    • Return to HFM DIAG TOP by long pressing the 6 ↩ button.
    • Forecefully remove on the Security PIN by long pressing the the ♪/SEL knob until the display reads UNLOCK.
    • The display will return to HFM DIAG TOP after 3 seconds. You can now proceed by repeating Step 9.
    • The update will start 3 seconds after you entered the correct Security PIN.
    • Wait for the update to finish.
    • Do not remove the flash drive or turn off the car while the update is running!
    • Once the update is completed the display will read UPDATE COMPLETE.
결론
Drive safe!
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
29,564 평판
안내서 71개를 작성함
German Translators German Translators 회원
Community
40 회원들
안내서 1,509개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 13
전체 시간: 444
