주요 콘텐츠로 건너뛰기
Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch)
필요한 것
  1. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Enter the Service Menu: 1 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Enter the Service Menu: 1 단계, 이미지 2개 중 2개
    • While holding the MENU button, press the segment on the display marked in red briefly.
    • Press and hold the segment of the display marked in orange for at least two seconds, while still holding the MENU button.
  2. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Navigate the Service Menu: 2 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Navigate the Service Menu: 2 단계, 이미지 2개 중 2개
    • Press on Hands Free Module.
    • While the Hands Free Module is in diagnosis mode, the sound input to the microphone unit is output directly through the speaker.
    • Check the Parts Number.
    • We'll need this later when downloading the Firmware file.
    • Check the Version Number.
    • If the Version Number is 19.00.000 you already have the last available Firmware installed and don't need to do anything.
  3. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Download the Firmware: 3 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Download the Firmware: 3 단계, 이미지 2개 중 2개
  4. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Move the File: 4 단계, 이미지 1개 중 1개
    • The flash drive needs to be formatted to FAT32 and should not be larger than 16GB. Additionally the head unit can be a bit picky and might not accept all flash drives. If it can't read your flash drive, just try a different one.
    • Copy the update.package file to the root directory of the USB flash drive.
  5. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Insert the flash drive: 5 단계, 이미지 1개 중 1개
    • Insert the USB flash drive into one of the USB ports in your car.
    • You can usually find a USB port inside the center console or below the head unit.
  6. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Initiate the Update: 6 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Initiate the Update: 6 단계, 이미지 2개 중 2개
    • Re-enter the Hands Free Module-Section of the Service Menu.
    • Press on the S/W-button.
    • If there is no S/W-button it means that the head unit didn't detect a valid file on the flash drive. This either means that you already have a version newer than the firmware file installed (as is the case for me), an incompatible firmware file, or that the system can't read the flash drive.
    • Confirm by pressing Yes.
  7. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Enter the Security PIN: 7 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Enter the Security PIN: 7 단계, 이미지 2개 중 2개
    • Enter your Security PIN.
    • If you don't have one set you can just enter 1234.
    • If you have forgotten you Security PIN, you can forcibly remove it by pressing the Unlock-Button in the Hands Free Module-Section of the Service Menu.
  8. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Wait: 8 단계, 이미지 2개 중 1개 Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Wait: 8 단계, 이미지 2개 중 2개
    • Wait for the update to finish.
    • Do not remove the flash drive or turn off the car while the update is running!
  9. Mitsubishi Hands Free Module Firmware Update (AM/FM-ST Electronic Tuning Radio, CD Player with Touch), Finish: 9 단계, 이미지 1개 중 1개
    • Press OK to finish the update.
결론
Drive safe!
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
28,678 평판
안내서 71개를 작성함
German Translators German Translators 회원
Community
36 회원들
안내서 1,223개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 78
전체 시간: 1,138
