주요 콘텐츠로 건너뛰기
Mitsubishi Hands Free Module Firmware Update (MMCS NR-242)
필요한 것
  1. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (not W-15 & W-17): 1 단계, 이미지 1/2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (not W-15 & W-17): 1 단계, 이미지 2/2
    • Enter the Service Menu by pressing and holding the SETTINGS and MAP-Buttons for 4 seconds.
  2. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Service Menu (W-15 & W-17): 2 단계, 이미지 1/1
    • Enter the Service Menu by pressing and holding the INFO/SET and SEEK-Buttons for 4 seconds.
  3. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Navigate the Service Menu: 3 단계, 이미지 1/2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Navigate the Service Menu: 3 단계, 이미지 2/2
    • Press on Hands Free Module.
    • While the Hands Free Module is in diagnosis mode, the sound input to the microphone unit is output directly through the speaker.
    • Check the Parts Number.
    • We'll need this later when downloading the Firmware file.
    • Check the Version Number.
    • If the Version Number is 19.00.000 or 50.00.000 you already have the last available Firmware installed and don't need to do anything.
  4. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Download the Firmware: 4 단계, 이미지 1/2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Download the Firmware: 4 단계, 이미지 2/2
  5. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Move the File: 5 단계, 이미지 1/1
    • The flash drive needs to be formatted to FAT32 and should not be larger than 16GB. Additionally the MMCS can be a bit picky and might not accept all flash drives. If it can't read your flash drive, just try a different one.
    • Copy the update.package file to the root directory of the USB flash drive.
  6. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Insert the flash drive: 6 단계, 이미지 1/1
    • Insert the USB flash drive into one of the USB ports in your car.
    • You can usually find a USB port inside the center console or below the head unit.
  7. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Initiate the Update: 7 단계, 이미지 1/1
    • Re-enter the Hands Free Module-Section of the Service Menu.
    • Press on the S/W Update-button.
    • If there is no S/W Update-button it means that the head unit didn't detect a valid file on the flash drive. This either means that you already have a version newer than the firmware file installed (as is the case for me), an incompatible firmware file, or that the system can't read the flash drive.
  8. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Enter the Security PIN: 8 단계, 이미지 1/1
    • Enter your Security PIN.
    • If you don't have one set you can just enter 1234.
    • If you have forgotten you Security PIN, you can forcibly remove it by pressing the Unlock-Button in the Hands Free Module-Section of the Service Menu.
  9. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Wait: 9 단계, 이미지 1/2 Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Wait: 9 단계, 이미지 2/2
    • Wait for the update to finish. This may take some time, don't worry if the progress bar stays at 0% for some time.
    • Do not remove the flash drive or turn off the car while the update is running!
    • If the update fails and the warning message states that you should make sure that the USB port is properly powered, you can just reboot the head unit and try again.
  10. Mitsubishi Hands Free Module Firmware Update (MMCS NR-242), Finish: 10 단계, 이미지 1/1
    • Press OK to finish the update.
결론
Drive safe!
다른 2명이 해당 안내서를 완성하였습니다.
Sebastian
회원 가입일: 08/19/18
22,551 평판
안내서 62개 작성하였습니다
German Translators German Translators 회원
Community
29 회원들
안내서 780개 작성하였습니다
댓글 6개
gut erklärt.Aber eine frage habe ich bringt so ein update was ?????
Alex Kahle - 답글
Ja, auf der Wiki Seite steht sogar welche Bugs gefixt wurden.
Sebastian -
Danke für deine Antwort
Frage habe die Versionsnummer 50.00.000 ist die alt ?
und bleibt mein DAB+ radio und meine lenkrad steuerung nach den update.
Alex Kahle - 답글
Version 50 ist die neuste und letzte, du musst also kein Update machen.
Sebastian -
I had tried update firmware in my outlander 2016. Now my car doesn't even detect hands free module at all. I had removed battery power supply and tried again but hands free module doesn't show in service mode. Please support.. How can i make it work? It seems there ia firmware mismatch. How can i repair it? Is there software available to connect with this HFM? Please help.
ABD - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 52
30일 전: 210
전체 시간: 2,002
