주요 콘텐츠로 건너뛰기
Mitsubishi T200 Screen Replacement
필요한 것
  1. Mitsubishi T200 Screen Replacement, Screen: 1 단계, 이미지 1/2 Mitsubishi T200 Screen Replacement, Screen: 1 단계, 이미지 2/2
    • Begin disassembling the phone by removing the phone back cover and battery.
  2. Mitsubishi T200 Screen Replacement: 2 단계, 이미지 1/1
    • To remove the back plate, loosen and remove the four screws by using a #00 Philips head screwdriver.
  3. Mitsubishi T200 Screen Replacement: 3 단계, 이미지 1/1
    • Separate the front plastic component from the motherboard component.
  4. Mitsubishi T200 Screen Replacement: 4 단계, 이미지 1/1
    • Take the circuit board off the motherboard.
  5. Mitsubishi T200 Screen Replacement: 5 단계, 이미지 1/2 Mitsubishi T200 Screen Replacement: 5 단계, 이미지 2/2
    • Unclip the four clips to remove the screen (connected to the clear plastic) from the circuit board.
  6. Mitsubishi T200 Screen Replacement: 6 단계, 이미지 1/2 Mitsubishi T200 Screen Replacement: 6 단계, 이미지 2/2
    • Remove the attached ribbon from the circuit board by prying open the gray plastic clip at the top right of the circuit board.
  7. Mitsubishi T200 Screen Replacement: 7 단계, 이미지 1/2 Mitsubishi T200 Screen Replacement: 7 단계, 이미지 2/2
    • We can now insert the new screen and reassemble the device.
    • Place the ribbon of the new screen into the clip on the top right of the circuit board.
  8. Mitsubishi T200 Screen Replacement: 8 단계, 이미지 1/1
    • Clip the new screen onto the circuit board.
  9. Mitsubishi T200 Screen Replacement: 9 단계, 이미지 1/1
    • Replace circut board back on top of motherboard.
  10. Mitsubishi T200 Screen Replacement: 10 단계, 이미지 1/1
    • Take the entire internal assembly and join it with the front plastic housing.
    • Ensure that the tops of both pieces clip into place before joining the bottom ones.
  11. Mitsubishi T200 Screen Replacement: 11 단계, 이미지 1/1
    • Join the phone's face assembly to the back plastic housing. Make sure you carefully insert the front into the antenna's clip first.
    • Snap the whole unit together.
  12. Mitsubishi T200 Screen Replacement: 12 단계, 이미지 1/1
    • Firmly replace screws into the backing.
결승점
다른 2명이 해당 안내서를 완성하였습니다.
Taylor Lewis
회원 가입일: 02/13/14
14 평판
안내서 1개 작성함
Ohio State, Team 1-5, Meza Spring 2014 Ohio State, Team 1-5, Meza Spring 2014 회원
OSU-MEZA-S14S1G5
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 835
