주요 콘텐츠로 건너뛰기
Mitsubishi VLT-HC3800LP Bulb Replacement
필요한 것
  1. Mitsubishi VLT-HC3800LP Bulb Replacement, Bulb: 1 단계, 이미지 1/1
    • Remove both screws as shown and gently pull the metallic frame. It is anchored on two small notches on the other side.
  2. Mitsubishi VLT-HC3800LP Bulb Replacement: 2 단계, 이미지 1/3 Mitsubishi VLT-HC3800LP Bulb Replacement: 2 단계, 이미지 2/3 Mitsubishi VLT-HC3800LP Bulb Replacement: 2 단계, 이미지 3/3
    • Remove both screws onn the handle side, and both dark screws on the opposite side.
    • Slightly pull the metal frame (1) and lift the housing top half (2) to reveal the bulb.
  3. Mitsubishi VLT-HC3800LP Bulb Replacement: 3 단계, 이미지 1/3 Mitsubishi VLT-HC3800LP Bulb Replacement: 3 단계, 이미지 2/3 Mitsubishi VLT-HC3800LP Bulb Replacement: 3 단계, 이미지 3/3
    • Remove the black stickers hiding both screws that will have to be removed in this step.
  4. Mitsubishi VLT-HC3800LP Bulb Replacement: 4 단계, 이미지 1/1
    • Lift the bulb and its holder from the housing frame.
    • It will then be easier to disconnect the cables
  5. Mitsubishi VLT-HC3800LP Bulb Replacement: 5 단계, 이미지 1/3 Mitsubishi VLT-HC3800LP Bulb Replacement: 5 단계, 이미지 2/3 Mitsubishi VLT-HC3800LP Bulb Replacement: 5 단계, 이미지 3/3
    • Remove the 4 screws and gently lift the frame maintaining the bulb.
    • Note the two notches which will only allow one way to mount the frame.
    • Note the bulb's contacts orientation.
    • Handle the replacement bulb with extreme care. Avoid touching it with bare hands. Bulbs don't like fingerprints at all!
  6. Mitsubishi VLT-HC3800LP Bulb Replacement: 6 단계, 이미지 1/1
    • Done!
    • Put the lamp back in place according to your projector's user manual.
결론
다른 2명이 해당 안내서를 완성하였습니다.
ralf
회원 가입일: 06/28/13
333 평판
안내서 2개 작성하였습니다
댓글 한 개
Did my Mitsubishi HC4000 today with lamp only..Found this after the event but useful anyway!
swingmanic - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 6
전체 시간: 8,686
