소개
The following entails a detailed list of instructions to properly and safely remove and replace a defective input/output board for a Mitsubishi WD57734 television.
  1. Before disassembling your television, be sure it is powered off and unplugged.
    • Before disassembling your television, be sure it is powered off and unplugged.
    • Remove the single 18 mm Phillips #1 screw on the lamp access panel.
  2. Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
    • Pull the lamp access panel off of the back panel of the television by pulling straight back on the left side of the panel near the screw then pulling to the left.
  3. Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
    • Loosen the two Phillips #2 screws securing the lamp housing to the television until the screws will swivel vertically.
      • These two screws are permanently attached to the lamp housing and cannot be removed completely.
  4. Using the handle, pull the lamp housing straight back out of the television.
    • Using the handle, pull the lamp housing straight back out of the television.
      • Do not touch the glass of the lamp with your bare hands. The oil from your fingers can distort the TV image and lead to other issues.
  5. Remove the following 8 Phillips #1 screws: One 22 mm Phillips #1 in the bottom right corner of the back panel.
    • Remove the following 8 Phillips #1 screws:
      • One 22 mm Phillips #1 in the bottom right corner of the back panel.
      • One 18 mm Phillips #1 in the top middle of the back panel.
      • Six 18 mm Phillips #1 in the rest of the back panel.
  6. Pull the back panel off of the television by gripping the sides and rotating it down.
    • Pull the back panel off of the television by gripping the sides and rotating it down.
  7. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  8. Removing the back panel exposes the input/output board cover plate.
    • Removing the back panel exposes the input/output board cover plate.
  9. Disconnect the back panel detection sensor by pressing down the white tab and pulling out the connection.
    • Disconnect the back panel detection sensor by pressing down the white tab and pulling out the connection.
  10. Remove the four 10 mm black Phillips #1 screws with fine thread that attach the protective case to the TV.
    • Remove the four 10 mm black Phillips #1 screws with fine thread that attach the protective case to the TV.
  11. Undo the white cable clasp holding the wires together.
    • Undo the white cable clasp holding the wires together.
    • Remove the wires from the cable organizer by carefully twisting the white loops and removing the wires from the clasp.
  12. Remove the following 11 screws from input/output panel. Eight 12 mm Phillips #1 (one screw on each side and six screws on the front panel). Three 10 mm black, fine thread Phillips #0 screws above the HDMI ports.
    • Remove the following 11 screws from input/output panel.
      • Eight 12 mm Phillips #1 (one screw on each side and six screws on the front panel).
      • Three 10 mm black, fine thread Phillips #0 screws above the HDMI ports.
  13. Use pliers to grasp the two washers around the coaxial inputs and rotate counterclockwise until they are removed.
    • Use pliers to grasp the two washers around the coaxial inputs and rotate counterclockwise until they are removed.
    • The washers are the flat silver pieces that twist around the silver cylindrical elements (these are the coaxial inputs).
  14. Pull the front cover plate straight back off and move it out of the way, exposing the input/output/ board.
    • Pull the front cover plate straight back off and move it out of the way, exposing the input/output/ board.
    • There are still connections on the input/output plate, so be careful.
  15. Remove three 10 mm silver, coarse thread Phillips #1 screws holding the input/output board to the case.
    • Remove three 10 mm silver, coarse thread Phillips #1 screws holding the input/output board to the case.
  16. Remove the connection to the front input/output wires by pressing down the white tab and gently pulling up.
    • Remove the connection to the front input/output wires by pressing down the white tab and gently pulling up.
  17. Disconnect the input/output board from the port in the main board by gently lifting upward and pull it out from the casing.
    • Disconnect the input/output board from the port in the main board by gently lifting upward and pull it out from the casing.
결론
Kylin
회원 가입일: 2012년 10월 02일
17 평판
안내서 1개 작성함
Cal Poly, Team 18-39, Regan Fall 2012 Cal Poly, Team 18-39, Regan Fall 2012 회원
CPSU-REGAN-F12S18G39
4 회원들
안내서 6개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 1,480
