주요 콘텐츠로 건너뛰기
Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement
필요한 것
  1. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade Cover: 1 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade Cover: 1 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade Cover: 1 단계, 이미지 3/3
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • If the clear water pump hose is connected, remove it now.
    • Loosen the plastic knob holding the saw's cutting head in place.
    • Lower the cutting head while keeping it steady.
  2. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 2 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 2 단계, 이미지 2/2
    • Unscrew the knob.
    • Remove it from the cutting head.
  3. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 3 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 3 단계, 이미지 2/2
    • Loosen the plastic knob holding the blade cover in place.
  4. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 4 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 4 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 4 단계, 이미지 3/3
    • Loosen the wing nut on the blade cover pivot shaft.
    • Remove the wing nut and accompanying washer.
  5. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 5 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 5 단계, 이미지 2/2
    • Pivot the blade cover up and pull it off the shaft.
  6. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade: 6 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade: 6 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Blade: 6 단계, 이미지 3/3
    • Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
    • Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
  7. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 7 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 7 단계, 이미지 2/2
    • Remove the hex nut.
    • Remove the outer flange.
  8. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 8 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 8 단계, 이미지 2/2
    • Remove the cutting blade.
    • The blade can be sharp, so handle with care.
  9. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Cutting Head: 9 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Cutting Head: 9 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Cutting Head: 9 단계, 이미지 3/3
    • Pull the entire cutting head straight off the shaft holding it in place.
  10. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement, Bottom Cover: 10 단계, 이미지 1/1
    • Remove the eight Phillips #2 screws on the underside of the cutting head.
  11. Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 11 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Bottom Cover Replacement: 11 단계, 이미지 2/2
    • Remove the bottom cover.
결론
Carsten Frauenheim
회원 가입일: 03/10/20
86,806 평판
안내서 332개 작성하였습니다
iFixit iFixit 회원
Community
137 회원들
안내서 17,047개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 125
