주요 콘텐츠로 건너뛰기
Mk Diamond Wet Saws MK660 2010 Motor Replacement
필요한 것
  1. Mk Diamond Wet Saws MK660 2010 Motor Replacement, Blade Cover: 1 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement, Blade Cover: 1 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement, Blade Cover: 1 단계, 이미지 3/3
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • If the clear water pump hose is connected, remove it now.
    • Loosen the plastic knob holding the saw's cutting head in place.
    • Lower the cutting head while keeping it steady.
  2. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 2 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 2 단계, 이미지 2/2
    • Unscrew the knob.
    • Remove it from the cutting head.
  3. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 3 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 3 단계, 이미지 2/2
    • Loosen the plastic knob holding the blade cover in place.
  4. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 4 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 4 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 4 단계, 이미지 3/3
    • Loosen the wing nut on the blade cover pivot shaft.
    • Remove the wing nut and accompanying washer.
  5. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 5 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 5 단계, 이미지 2/2
    • Pivot the blade cover up and pull it off the shaft.
  6. Mk Diamond Wet Saws MK660 2010 Motor Replacement, Blade: 6 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement, Blade: 6 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement, Blade: 6 단계, 이미지 3/3
    • Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
    • Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
  7. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 7 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 7 단계, 이미지 2/2
    • Remove the hex nut.
    • Remove the outer flange.
  8. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 8 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 8 단계, 이미지 2/2
    • Remove the cutting blade.
    • The blade can be sharp, so handle with care.
  9. Mk Diamond Wet Saws MK660 2010 Motor Replacement, Cutting Head: 9 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement, Cutting Head: 9 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement, Cutting Head: 9 단계, 이미지 3/3
    • Pull the entire cutting head straight off the shaft holding it in place.
  10. Mk Diamond Wet Saws MK660 2010 Motor Replacement, Bottom Cover: 10 단계, 이미지 1/1
    • Remove the eight Phillips #2 screws on the underside of the cutting head.
  11. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 11 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 11 단계, 이미지 2/2
    • Remove the bottom cover.
  12. Mk Diamond Wet Saws MK660 2010 Motor Replacement, Motor: 12 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement, Motor: 12 단계, 이미지 2/2
    • Remove the Phillips #2 screw holding the ground wires to the chassis.
    • Loosen the wires from each other.
    • The motor's ground wire is green with a yellow stripe.
    • Reassembly tip: there are three ground wires attached here that will need to be reinstalled upon reassembly.
  13. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 13 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 13 단계, 이미지 2/2
    • Remove the black wire's plug from the 4-pin rectifier.
    • These plugs have two wires each, so removing one plug removes two wires.
  14. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 14 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 14 단계, 이미지 2/2
    • Remove the red/orange wire combo plug from the 4-pin rectifier.
    • Use needle-nose pliers if you can't reach this plug with your fingers.
  15. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 15 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 15 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 15 단계, 이미지 3/3
    • Be very careful with this connection, as even minimal bending can break the metal conductor in half.
    • Use a pick to slightly pry up on the crimped metal arms holding the red and orange wires together.
    • Repeat for both sides to loosen the connector.
  16. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 16 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 16 단계, 이미지 2/2
    • Remove the red wire from the orange wire.
  17. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 17 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 17 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 17 단계, 이미지 3/3
    • Use two flathead screwdrivers to carefully pry the inner flange off the motor shaft.
    • You may need to use the two screwdrivers to "walk" the flange off—it's press-fit onto the shaft. Try prying on various positions of the flange and rotating it as you work.
    • Remove the inner flange.
  18. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 18 단계, 이미지 1/1
    • Remove the four Phillips #2 screws holding the motor in place.
  19. Mk Diamond Wet Saws MK660 2010 Motor Replacement: 19 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 19 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Motor Replacement: 19 단계, 이미지 3/3
    • Grab the motor with both hands and tilt it slightly upward.
    • While keeping the motor tilted up, pull back and up to clear the electrical components behind the motor.
    • Remove the motor.
    • You may need to bend the thermal overload switch slightly in order to lift the motor out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Carsten Frauenheim
회원 가입일: 03/10/20
112,834 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,732개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 39
전체 시간: 1,012
