주요 콘텐츠로 건너뛰기
Mk Diamond Wet Saws MK660 2010 Power Cord Replacement
필요한 것
  1. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Blade Cover: 1 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Blade Cover: 1 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Blade Cover: 1 단계, 이미지 3/3
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • If the clear water pump hose is connected, remove it now.
    • Loosen the plastic knob holding the saw's cutting head in place.
    • Lower the cutting head while keeping it steady.
  2. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 2 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 2 단계, 이미지 2/2
    • Unscrew the knob.
    • Remove it from the cutting head.
  3. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 3 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 3 단계, 이미지 2/2
    • Loosen the plastic knob holding the blade cover in place.
  4. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 4 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 4 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 4 단계, 이미지 3/3
    • Loosen the wing nut on the blade cover pivot shaft.
    • Remove the wing nut and accompanying washer.
  5. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 5 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 5 단계, 이미지 2/2
    • Pivot the blade cover up and pull it off the shaft.
  6. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Blade: 6 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Blade: 6 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Blade: 6 단계, 이미지 3/3
    • Insert the provided spanner wrench into one of the four tightening holes on the inner flange behind the blade.
    • Use the the provided nut wrench to loosen the hex nut while providing counterforce with the spanner wrench.
  7. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 7 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 7 단계, 이미지 2/2
    • Remove the hex nut.
    • Remove the outer flange.
  8. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 8 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 8 단계, 이미지 2/2
    • Remove the cutting blade.
    • The blade can be sharp, so handle with care.
  9. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Cutting Head: 9 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Cutting Head: 9 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Cutting Head: 9 단계, 이미지 3/3
    • Pull the entire cutting head straight off the shaft holding it in place.
  10. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Bottom Cover: 10 단계, 이미지 1/1
    • Remove the eight Phillips #2 screws on the underside of the cutting head.
  11. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 11 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 11 단계, 이미지 2/2
    • Remove the bottom cover.
  12. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Motor: 12 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Motor: 12 단계, 이미지 2/2
    • Remove the Phillips #2 screw holding the ground wires to the chassis.
    • Loosen the wires from each other.
    • The motor's ground wire is green with a yellow stripe.
    • Reassembly tip: there are three ground wires attached here that will need to be reinstalled upon reassembly.
  13. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 13 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 13 단계, 이미지 2/2
    • Remove the black wire's plug from the 4-pin rectifier.
    • These plugs have two wires each, so removing one plug removes two wires.
  14. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 14 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 14 단계, 이미지 2/2
    • Remove the red/orange wire combo plug from the 4-pin rectifier.
    • Use needle-nose pliers if you can't reach this plug with your fingers.
  15. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 15 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 15 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 15 단계, 이미지 3/3
    • Be very careful with this connection, as even minimal bending can break the metal conductor in half.
    • Use a pick to slightly pry up on the crimped metal arms holding the red and orange wires together.
    • Repeat for both sides to loosen the connector.
  16. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 16 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 16 단계, 이미지 2/2
    • Remove the red wire from the orange wire.
  17. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 17 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 17 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 17 단계, 이미지 3/3
    • Use two flathead screwdrivers to carefully pry the inner flange off the motor shaft.
    • You may need to use the two screwdrivers to "walk" the flange off—it's press-fit onto the shaft. Try prying on various positions of the flange and rotating it as you work.
    • Remove the inner flange.
  18. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 18 단계, 이미지 1/1
    • Remove the four Phillips #2 screws holding the motor in place.
  19. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 19 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 19 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 19 단계, 이미지 3/3
    • Grab the motor with both hands and tilt it slightly upward.
    • While keeping the motor tilted up, pull back and up to clear the electrical components behind the motor.
    • Remove the motor.
    • You may need to bend the thermal overload switch slightly in order to lift the motor out.
  20. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Power Cord: 20 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement, Power Cord: 20 단계, 이미지 2/2
    • Remove the electrical tape from the twist-on wire connector connecting the three white wires.
  21. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 21 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 21 단계, 이미지 2/2
    • Remove the twist-on wire connector.
  22. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 22 단계, 이미지 1/1
    • Twist the three white wires apart from each other.
  23. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 23 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 23 단계, 이미지 2/2
    • Remove the black wire from the switch assembly.
  24. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 24 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 24 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 24 단계, 이미지 3/3
    • Use wire cutters to cut the angled plug off the end of the black wire so it can slide out of the power cord opening.
  25. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 25 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 25 단계, 이미지 2/2
    • Use an adjustable wrench to loosen the hex nut closest to the wall plug side of the power cord.
  26. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 26 단계, 이미지 1/2 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 26 단계, 이미지 2/2
    • Pull back the flex guard from the cutting head chassis.
  27. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 27 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 27 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 27 단계, 이미지 3/3
    • Make sure all power cord wires are disconnected before pulling the power cord out of the cutting head.
    • Grab the outer sheath and slowly pull the power cord out of the cutting head.
    • Remove the power cord.
  28. Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 28 단계, 이미지 1/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 28 단계, 이미지 2/3 Mk Diamond Wet Saws MK660 2010 Power Cord Replacement: 28 단계, 이미지 3/3
    • If your replacement power cord does not have quick disconnect plugs on the end of its wires, strip about half an inch of insulation off of each wire to install new crimp connectors.
    • Reassembly tip: This needs to be done after the cord is fed back into the cutting head, otherwise it won't fit.
결론
Carsten Frauenheim
회원 가입일: 03/10/20
113,151 평판
안내서 338개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,767개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 498
