주요 콘텐츠로 건너뛰기
Modal MD-SPBT01 LED Light Wiring Replacement
필요한 것
  1. Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: 1 단계, 이미지 1/2 Modal MD-SPBT01 LED Light Wiring Replacement, LED Light Wiring: 1 단계, 이미지 2/2
    • Use your plastic opening tool to pry the metal speaker cover off.
  2. Modal MD-SPBT01 LED Light Wiring Replacement: 2 단계, 이미지 1/1
    • You can now use the Phillips #00 screwdriver to remove the four screws.
  3. Modal MD-SPBT01 LED Light Wiring Replacement: 3 단계, 이미지 1/1
    • With the screws removed, you can now remove the top piece of the speaker to gain access to the interior.
  4. Modal MD-SPBT01 LED Light Wiring Replacement: 4 단계, 이미지 1/1
    • Locate the LED wire connection and remove it from the mother board.
    • To make replacing the LED wiring easier, remove the speaker wire to fully disconnect the speaker from the mother board.
  5. Modal MD-SPBT01 LED Light Wiring Replacement: 5 단계, 이미지 1/1
    • Now you can remove the wiring from the speaker side of the device.
    • It might take a bit of work to remove the wires because they are glued down on this side.
  6. Modal MD-SPBT01 LED Light Wiring Replacement: 6 단계, 이미지 1/1
    • Now with the LED wiring removed, a new wire can be installed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Hall
회원 가입일: 10/13/15
258 평판
안내서 2개 작성하였습니다
Sam Houston State, Team 2-4, Blackburne Fall 2015 Sam Houston State, Team 2-4, Blackburne Fall 2015 회원
SHSU-BLACKBURNE-F15S2G4
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 6
전체 시간: 627
