주요 콘텐츠로 건너뛰기
Modal Rechargeable Wine Opener Power Button Replacement
필요한 것
  1. Modal Rechargeable Wine Opener Power Button Replacement, Modal Rechargeable Wine Opener power button: 1 단계, 이미지 1개 중 1개
    • Carefully place the spudger under the black cylindrical ring and pry it off the top.
  2. Modal Rechargeable Wine Opener Power Button Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the spring
    • Remove the spring guide as well to obtain clear access to the screws
  3. Modal Rechargeable Wine Opener Power Button Replacement: 3 단계, 이미지 3개 중 1개 Modal Rechargeable Wine Opener Power Button Replacement: 3 단계, 이미지 3개 중 2개 Modal Rechargeable Wine Opener Power Button Replacement: 3 단계, 이미지 3개 중 3개
    • Remove all four 4mm screws with a J1 Screwdriver
    • Remove the clear cylindrical cap
  4. Modal Rechargeable Wine Opener Power Button Replacement: 4 단계, 이미지 3개 중 1개 Modal Rechargeable Wine Opener Power Button Replacement: 4 단계, 이미지 3개 중 2개 Modal Rechargeable Wine Opener Power Button Replacement: 4 단계, 이미지 3개 중 3개
    • Apply pressure to both of the springs on the surface near the corkscrew, releasing the button port.
  5. Modal Rechargeable Wine Opener Power Button Replacement: 5 단계, 이미지 3개 중 1개 Modal Rechargeable Wine Opener Power Button Replacement: 5 단계, 이미지 3개 중 2개 Modal Rechargeable Wine Opener Power Button Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the malfunctioning buttons from the plastic frame.
결론
작성자
4다른 기여자 명과 함께
Lauren Spicher
회원 가입일: 02/15/17
101 평판
안내서 1개를 작성함
USF Tampa, Team 15-4, Remmell Spring 2017 USF Tampa, Team 15-4, Remmell Spring 2017 회원
USFT-REMMELL-S17S15G4
4 회원들
안내서 2개를 작성함
4가이드 댓글
where do you by the replacement switch?
Stan Okumura - 답글
are there any posts for fixing the usb charging port?
Cristian Sanabria - 답글
If the lights work, the buttons are not the problem. I can get the cork screw to turn manually, but it will not continue run beyond a few tries. Must be the motor.
tom.o@mac.com - 답글
Could be also the battery. I will try to change the battery.
Daniel Siegenthaler -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 25
전체 시간: 9,220
