주요 콘텐츠로 건너뛰기
필요한 것
해당 분해도는 수리 안내서가 아닙니다. Model CVS124A 수리는 저희 서비스 설명서를 사용하십시오.
  1. Model CVS124A Teardown, Screws Removal: 1 단계, 이미지 1/1
    • Locate the screw on the handle and remove them with a Phillips screwdriver.
    • All of the hair dryer’s components are held together by these two screws. Parts may quickly separate after screw removal.
  2. Model CVS124A Teardown, Handle removal (top): 2 단계, 이미지 1/2 Model CVS124A Teardown, Handle removal (top): 2 단계, 이미지 2/2
    • Remove the top portion of the handle.
    • The model information and warnings are engraved on the top portion.
  3. Model CVS124A Teardown, Switch removal: 3 단계, 이미지 1/1
    • Remove the settings switch by lifting straight up.
  4. Model CVS124A Teardown, Inside component removal: 4 단계, 이미지 1/1
    • Remove the internal switch from the rear portion of the handle.
  5. Model CVS124A Teardown, Handle removal (lower): 5 단계, 이미지 1/1
    • Remove the lower portion of the handle by sliding the peg out of the slot at the top of the handle.
  6. Model CVS124A Teardown, Material of the handle: 6 단계, 이미지 1/1
    • Handle - ABS injection moulding
  7. Model CVS124A Teardown: 7 단계, 이미지 1/2 Model CVS124A Teardown: 7 단계, 이미지 2/2
    • Take off the protective jacket outside the wire.
  8. Model CVS124A Teardown: 8 단계, 이미지 1/2 Model CVS124A Teardown: 8 단계, 이미지 2/2
    • Separate the iron case with the back case by using 6.5mm flathead screwdriver. Take off the fan after separation.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
  9. Model CVS124A Teardown: 9 단계, 이미지 1/2 Model CVS124A Teardown: 9 단계, 이미지 2/2
    • The fan motor
  10. Model CVS124A Teardown, Separate the two cases: 10 단계, 이미지 1/1
    • Separate the back and front case by using the 6.5mm flathead screwdriver.
  11. Model CVS124A Teardown: 11 단계, 이미지 1/2 Model CVS124A Teardown: 11 단계, 이미지 2/2
    • At this point you can pull the complete electronic sub assembly from the front case.
    • Coils
  12. Model CVS124A Teardown: 12 단계, 이미지 1/1
    • All the parts after the teardown.
任心怡
회원 가입일: 10/15/18
205 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 750
