필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Locate the screw on the handle and remove them with a Phillips screwdriver.
Remove the lower portion of the handle by sliding the peg out of the slot at the top of the handle.
Separate the iron case with the back case by using 6.5mm flathead screwdriver. Take off the fan after separation.
Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
Separate the back and front case by using the 6.5mm flathead screwdriver.
At this point you can pull the complete electronic sub assembly from the front case.
Coils
