주요 콘텐츠로 건너뛰기
Model O- Mouse Cable Replacement
필요한 것
  1. Model O- Mouse Cable Replacement, Mouse Cable: 1 단계, 이미지 1/3 Model O- Mouse Cable Replacement, Mouse Cable: 1 단계, 이미지 2/3 Model O- Mouse Cable Replacement, Mouse Cable: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Turn the mouse over so that the feet are facing you.
    • Remove the bottom two mouse feet using tweezers.
    • If you plan on reusing the mouse feet place them with the adhesive side up.
  2. Model O- Mouse Cable Replacement: 2 단계, 이미지 1/2 Model O- Mouse Cable Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the two screws that are under the mouse feet.
  3. Model O- Mouse Cable Replacement: 3 단계, 이미지 1/3 Model O- Mouse Cable Replacement: 3 단계, 이미지 2/3 Model O- Mouse Cable Replacement: 3 단계, 이미지 3/3
    • Slide the base away from the top housing to avoid the front clips.
    • Lift the top and place it down diagonal over the base, exposing the 5-pin connector.
    • Avoid putting strain on the thin LED ribbon cables.
  4. Model O- Mouse Cable Replacement: 4 단계, 이미지 1/2 Model O- Mouse Cable Replacement: 4 단계, 이미지 2/2
    • Use two fingers to grasp the top of the 5-pin connector under the edges and slowly lift the connector. If it is difficult, wiggle the plug slightly.
    • Do not pull on the wires.
    • Remove the cable from around the circuit board and from the hole on the front of the mouse.
  5. Model O- Mouse Cable Replacement: 5 단계, 이미지 1/2 Model O- Mouse Cable Replacement: 5 단계, 이미지 2/2
    • Insert the new cable's 5-pin connector plug (red) into the 5-pin connector socket (orange).
    • Do not push on the wires.
  6. Model O- Mouse Cable Replacement: 6 단계, 이미지 1/2 Model O- Mouse Cable Replacement: 6 단계, 이미지 2/2
    • Route the new cable through the slit in the circuit board.
    • Route the new cable behind the pillars.
    • Route the cable through the hole at the front of the mouse. Some cables have a fitted square plastic piece that positions the cable, some have thermoplastic which requires the user to position it themselves.
    • The cable may not stay in place until the top housing is securely fastened back on.
  7. Model O- Mouse Cable Replacement: 7 단계, 이미지 1/2 Model O- Mouse Cable Replacement: 7 단계, 이미지 2/2
    • Join the top and bottom housing together with the top around 1cm ahead of the bottom, then pull the top housing back as illustrated.
    • Once the two sides of the shell are together apply pressure until at least one screw is securely fastening them together.
  8. Model O- Mouse Cable Replacement: 8 단계, 이미지 1/1
    • Screw the two screws back in with a Phillips #0 screwdriver.
    • Do not apply too much force or you risk stripping the screw holes.
  9. Model O- Mouse Cable Replacement: 9 단계, 이미지 1/2 Model O- Mouse Cable Replacement: 9 단계, 이미지 2/2
    • Reapply the mouse feet with the adhesive side sticking to the mouse.
    • There are plastic ridges to help guide the user where to place the mouse feet.
    • Certain mouse cables come with new mouse feet which can be applied here instead of reapplying the old feet.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
Theo SW
회원 가입일: 01/22/21
241 평판
안내서 1개 작성함
York University, Team S2-G24, O'Regan Winter 2021 York University, Team S2-G24, O'Regan Winter 2021 회원
YORK-O'REGAN-W21S2G24
1 회원
안내서 3개 작성하였습니다
댓글 2개
Where can I get the replacement cable for it?
Ekke Sten - 답글
does glorius them selfs sell replacment parts ?
aniss-97 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 48
30일 전: 169
전체 시간: 11,403
