주요 콘텐츠로 건너뛰기
Moen Posi-Temp Cartridge Part #1112b Replacement
필요한 것
  1. Moen Posi-Temp Cartridge Part #1112b Replacement, Moen Posi-Temp Cartridge Part #1112b: 1 단계, 이미지 1개 중 1개
    • Turn the water shutoff valve counter-clockwise to the "off" position.
  2. Moen Posi-Temp Cartridge Part #1112b Replacement: 2 단계, 이미지 1개 중 1개
    • Open both the hot and cold taps of a nearby faucet or shower until the water no longer flows.
  3. Moen Posi-Temp Cartridge Part #1112b Replacement: 3 단계, 이미지 2개 중 1개 Moen Posi-Temp Cartridge Part #1112b Replacement: 3 단계, 이미지 2개 중 2개
    • Turn the handle of the shower valve 180 degrees until it is in the "up" or "on" position.
  4. Moen Posi-Temp Cartridge Part #1112b Replacement: 4 단계, 이미지 2개 중 1개 Moen Posi-Temp Cartridge Part #1112b Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the handle screw with an Allen wrench.
    • Remove the handle.
  5. Moen Posi-Temp Cartridge Part #1112b Replacement: 5 단계, 이미지 2개 중 1개 Moen Posi-Temp Cartridge Part #1112b Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the handle adaptor screw with a Phillips screwdriver.
    • Remove the handle adaptor simply by pulling it out.
  6. Moen Posi-Temp Cartridge Part #1112b Replacement: 6 단계, 이미지 1개 중 1개
    • Pull out the white key/adjustable limit stop.
  7. Moen Posi-Temp Cartridge Part #1112b Replacement: 7 단계, 이미지 3개 중 1개 Moen Posi-Temp Cartridge Part #1112b Replacement: 7 단계, 이미지 3개 중 2개 Moen Posi-Temp Cartridge Part #1112b Replacement: 7 단계, 이미지 3개 중 3개
    • Gently pull out the stop tube.
  8. Moen Posi-Temp Cartridge Part #1112b Replacement: 8 단계, 이미지 3개 중 1개 Moen Posi-Temp Cartridge Part #1112b Replacement: 8 단계, 이미지 3개 중 2개 Moen Posi-Temp Cartridge Part #1112b Replacement: 8 단계, 이미지 3개 중 3개
    • Using the Phillips head screwdriver, remove the two screws located at the top right corner and bottom left corner.
    • Remove the metal plate.
  9. Moen Posi-Temp Cartridge Part #1112b Replacement: 9 단계, 이미지 3개 중 1개 Moen Posi-Temp Cartridge Part #1112b Replacement: 9 단계, 이미지 3개 중 2개 Moen Posi-Temp Cartridge Part #1112b Replacement: 9 단계, 이미지 3개 중 3개
    • Slide the tip of needle-nose pliers under the notch of the retaining clip and pull the clip upwards.
  10. Moen Posi-Temp Cartridge Part #1112b Replacement: 10 단계, 이미지 3개 중 1개 Moen Posi-Temp Cartridge Part #1112b Replacement: 10 단계, 이미지 3개 중 2개 Moen Posi-Temp Cartridge Part #1112b Replacement: 10 단계, 이미지 3개 중 3개
    • Clamp firmly onto the brass tube with a pair of vice grips and gently but firmly pull out the cartridge.
  11. Moen Posi-Temp Cartridge Part #1112b Replacement: 11 단계, 이미지 2개 중 1개 Moen Posi-Temp Cartridge Part #1112b Replacement: 11 단계, 이미지 2개 중 2개
    • Insert the new Moen Posi-Temp cartridge.
  12. Moen Posi-Temp Cartridge Part #1112b Replacement: 12 단계, 이미지 1개 중 1개
    • Insert the new cartridge into the valve assembly.
    • Ensure that the H/C symbols are facing up.
    • Ensure that the notch on the brass tube is also facing up.
결론
작성자
1다른 기여자 명과 함께
John Mendoza
회원 가입일: 09/17/20
205 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 32
전체 시간: 1,538
