주요 콘텐츠로 건너뛰기
Moen Single Handle Faucet Cartridge (Model: 1225) Replacement
필요한 것
  1. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: 1 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: 1 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement, Cartridge: 1 단계, 이미지 3/3
    • Turn off the main water supply by inserting your meter key into the curb stop valve handle and rotating it 180 degrees counterclockwise to the closed position.
    • If you have a gate valve, rotate the valve counterclockwise to the closed position.
  2. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 2 단계, 이미지 1/2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 2 단계, 이미지 2/2
    • Open the faucet handle to relieve water pressure until there is no water flow.
  3. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 3 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 3 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 3 단계, 이미지 3/3
    • Remove the handle cap.
  4. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 4 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 4 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 4 단계, 이미지 3/3
    • Use a Phillips screwdriver to unscrew the connecting handle screw (10-24 x 1-1/8" Button Head Phillips screw).
    • Remove the handle.
  5. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 5 단계, 이미지 1/2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 5 단계, 이미지 2/2
    • Pull out the stop tube.
  6. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 6 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 6 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 6 단계, 이미지 3/3
    • Remove the washer from the brass stem.
  7. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 7 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 7 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 7 단계, 이미지 3/3
    • Using needle-nose pliers, clamp the tip of the notch of the cartridge retaining clip and pull it upwards to remove.
  8. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 8 단계, 이미지 1/2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 8 단계, 이미지 2/2
    • Using a pair of vise grips, clamp firmly onto the brass stem and pull out the old 1225 cartridge.
  9. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 9 단계, 이미지 1/2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 9 단계, 이미지 2/2
    • On the new 1225 cartridge, orient the volume control holes parallel to the floor.
    • Insert the new 1225 cartridge into the valve.
  10. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 10 단계, 이미지 1/2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 10 단계, 이미지 2/2
    • Insert the white twisting cap into the grooves of the new cartridge and push the cartridge into the valve.
    • Remove the white twisting cap.
  11. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 11 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 11 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 11 단계, 이미지 3/3
    • Reinstall the cartridge retainer clip by sliding the clip into the valve.
  12. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 12 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 12 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 12 단계, 이미지 3/3
    • Turn on the main water supply by inserting your meter key into the curb stop valve handle and rotating it 180 degrees clockwise to the open position.
    • If you have a gate valve, rotate the valve clockwise to the open position.
  13. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 13 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 13 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 13 단계, 이미지 3/3
    • Clamp the brass stem with vice grips and rotate it 90 degrees to the left, checking the water temperature for hot water.
    • From this position, rotate the brass stem 180 degrees to the right, checking the water temperature for cold water.
    • If the hot and cold operations are reversed, use vice grips to clamp onto the brass stem and rotate it 180 degrees from the original position.
  14. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 14 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 14 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 14 단계, 이미지 3/3
    • Push the washer onto the brass stem.
  15. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 15 단계, 이미지 1/2 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 15 단계, 이미지 2/2
    • Replace the stop tube by pushing it onto the valve.
  16. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 16 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 16 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 16 단계, 이미지 3/3
    • Insert the handle onto the stop tube.
    • Use a Phillips screwdriver to screw in the connecting handle screw (10-24 x 1-1/8" Button Head Phillips screw).
  17. Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 17 단계, 이미지 1/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 17 단계, 이미지 2/3 Moen Single Handle Faucet Cartridge (Model: 1225) Replacement: 17 단계, 이미지 3/3
    • Replace the handle cap.
결론
If your faucet continues to leak after replacing the cartridge, there may be another underlying issue causing the problem with your plumbing. Inspect the O-rings, seals, and other components of the faucet for any damage and consult professional assistance to resolve the issue.
다른 한 분이 해당 안내서를 완성하였습니다.
Faith Larimore
회원 가입일: 07/05/23
295 평판
안내서 1개 작성함
Austin Community College, Team 1-4, Meigs Summer 2023 Austin Community College, Team 1-4, Meigs Summer 2023 회원
AUSTINCC-MEIGS-SU23S1G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 30
30일 전: 135
전체 시간: 984
