소개
The heating element and temperature sensor are very important in a 3D printer. The former helps to melt the printing material to allow construction, and the latter monitors the temperature of the hot end. When both are faulty, the printer will begin to fail and require replacement.
That is the purpose of this guide: to help to replace both the heating element and the temperature sensor. Additionally, if only one of the two components need replacement, the parts of each step involving the other element can be ignored.
필요한 것
Use needle nose pliers to remove the two spring clips on either side of the shroud covering the hotend.
Remove the fan with your hand.
2가이드 댓글
Very good. It would be simpler, for those who can contemplate it, to just cut the wires to the heating element and thermistor a couple of inches away from them. and splice the new ones in, paying attention to heat-shrinking the joints. Then you don't have to rewire all the way back to the PCB. You need soldering and heatshrinking facilities for this procedure.
The 'you need' list should also include zip ties.
Where did you get the new heating element? Would this fix the issue of the printer not printing anything, even after preheating it? That's why mine has been collecting dust for years.
