소개
Oftentimes the ear cushions get ripped, and these will eventually need to be replaced. This has been known to be a very common issue when using these headphones.
If they are not ripped, they may just need to be put back into place and potentially glued down. Doing all this is very easy and will not require more than 5 minutes of your time.
필요한 것
Grab the ear cushion by the bottom, pull down, forward and then up to take off the cushion as a whole.
다른 한 분이 해당 안내서를 완성하였습니다.
