주요 콘텐츠로 건너뛰기
Monster DNA Speaker Replacement
필요한 것
  1. Monster DNA Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Monster DNA Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Remove the ear cushions and use a Phillips #2 screwdriver to unscrew the three 5mm screws.
    • Desolder the wires to completely remove the speaker.
    • Take note of the proper location of the wires reassembly.
    • Use a heatgun to loosen the glue holding down the speaker.
    • Be careful to take safety precautions such as gloves as not to cause injury.
  2. Monster DNA Speaker Replacement: 4 단계, 이미지 1/1
    • Pry the speaker out using a plastic opening tool or metal spudger.
    • Using too much force will damage the headphones and the new speaker may not go back into place properly.
  3. Monster DNA Speaker Replacement: 5 단계, 이미지 1/1
    • Insert new speaker and solder the five wires into corresponding positions onto the new speaker.
결론
Kevin Costello
회원 가입일: 03/22/17
231 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S4-G5, Julie Spring 2017 UMass Dartmouth, Team S4-G5, Julie Spring 2017 회원
UMASSD-JULIE-S17S4G5
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 5
전체 시간: 1,587
