주요 콘텐츠로 건너뛰기
Monster SoundStage S1 Mini Speaker Replacement
필요한 것
  1. Monster SoundStage S1 Mini Speaker Replacement, Speaker: 1 단계, 이미지 1/2 Monster SoundStage S1 Mini Speaker Replacement, Speaker: 1 단계, 이미지 2/2
    • Remove the speaker wires from the motherboard by pinching the plastic tab at the end of the cable and pulling towards you.
  2. Monster SoundStage S1 Mini Speaker Replacement: 2 단계, 이미지 1/2 Monster SoundStage S1 Mini Speaker Replacement: 2 단계, 이미지 2/2
    • Unscrew 1.2 cm Torx security screw, holding the silver circle connector, to disconnect the wire from the speakerboard to the motherboard
  3. Monster SoundStage S1 Mini Speaker Replacement: 3 단계, 이미지 1/1
    • Remove the black putty from the speaker wires at both ends of the speaker board.
  4. Monster SoundStage S1 Mini Speaker Replacement: 4 단계, 이미지 1/3 Monster SoundStage S1 Mini Speaker Replacement: 4 단계, 이미지 2/3 Monster SoundStage S1 Mini Speaker Replacement: 4 단계, 이미지 3/3
    • Solder the black plastic encasing the red and black wires.
  5. Monster SoundStage S1 Mini Speaker Replacement: 5 단계, 이미지 1/2 Monster SoundStage S1 Mini Speaker Replacement: 5 단계, 이미지 2/2
    • Remove both the black and red wires with pliers
    • Pliers may stick to speaker because it is magnetic.
  6. Monster SoundStage S1 Mini Speaker Replacement: 6 단계, 이미지 1/2 Monster SoundStage S1 Mini Speaker Replacement: 6 단계, 이미지 2/2
    • Tuck wires through the hole where the speaker is located, then gently push the speaker out.
    • The 1.2 cm Torx security screws that stayed in place near the speaker will now fall out.
    • To remove the other speaker repeat steps 3-6
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Heather Carrillo
회원 가입일: 09/12/16
412 평판
안내서 2개 작성하였습니다
CSU Fullerton, Team 2-6, Bruce Fall 2016 CSU Fullerton, Team 2-6, Bruce Fall 2016 회원
CSUF-BRUCE-F16S2G6
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 493
