주요 콘텐츠로 건너뛰기
Monster Soundstage S2 Front Speakers Replacement
필요한 것
  1. Monster Soundstage S2 Front Speakers Replacement, Speaker Grille: 1 단계, 이미지 1/2 Monster Soundstage S2 Front Speakers Replacement, Speaker Grille: 1 단계, 이미지 2/2
    • Use a spudger or your fingers to pry off and remove the rubber pad on the bottom of the speaker.
  2. Monster Soundstage S2 Front Speakers Replacement: 2 단계, 이미지 1/3 Monster Soundstage S2 Front Speakers Replacement: 2 단계, 이미지 2/3 Monster Soundstage S2 Front Speakers Replacement: 2 단계, 이미지 3/3
    • Remove the five 10mm screws with a TR 10 screwdriver.
    • Use a spudger to break the remaining adhesive holding the grille to the speaker body.
    • Be sure you don't bend the grille; it is not free from the speaker yet.
  3. Monster Soundstage S2 Front Speakers Replacement: 3 단계, 이미지 1/1
    • Flip speaker around and use a plastic opening tool to remove the top panel from the speaker.
  4. Monster Soundstage S2 Front Speakers Replacement: 4 단계, 이미지 1/3 Monster Soundstage S2 Front Speakers Replacement: 4 단계, 이미지 2/3 Monster Soundstage S2 Front Speakers Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool to remove the foam and uncover four more screws.
    • Use a TR 10 screwdriver to remove the five 10mm screws on the top of the speaker.
  5. Monster Soundstage S2 Front Speakers Replacement: 5 단계, 이미지 1/2 Monster Soundstage S2 Front Speakers Replacement: 5 단계, 이미지 2/2
    • Carefully remove the top cover.
    • Be careful not to tear or stress the cable that provides power to the power LED.
  6. Monster Soundstage S2 Front Speakers Replacement: 6 단계, 이미지 1/2 Monster Soundstage S2 Front Speakers Replacement: 6 단계, 이미지 2/2
    • Use a TR 10 screwdriver to remove two of the 10mm screws that secure the speaker grille.
    • Do not attempt to remove the grille just yet.
  7. Monster Soundstage S2 Front Speakers Replacement: 7 단계, 이미지 1/3 Monster Soundstage S2 Front Speakers Replacement: 7 단계, 이미지 2/3 Monster Soundstage S2 Front Speakers Replacement: 7 단계, 이미지 3/3
    • With the top panel removed, use a spudger to remove the display panel.
    • The clips on the display panel are quite fragile. Pry up both edges of the display before attempting removal.
    • Use a TR 10 screwdriver to remove the four final 10mm screws securing the speaker grille.
  8. Monster Soundstage S2 Front Speakers Replacement: 8 단계, 이미지 1/1
    • Remove the front speaker grille.
  9. Monster Soundstage S2 Front Speakers Replacement, Front Speakers: 9 단계, 이미지 1/3 Monster Soundstage S2 Front Speakers Replacement, Front Speakers: 9 단계, 이미지 2/3 Monster Soundstage S2 Front Speakers Replacement, Front Speakers: 9 단계, 이미지 3/3
    • After removing grille, you will see the speakers.
    • Remove the eight 10mm screws that surround the speakers. There will be four around each speaker.
  10. Monster Soundstage S2 Front Speakers Replacement: 10 단계, 이미지 1/2 Monster Soundstage S2 Front Speakers Replacement: 10 단계, 이미지 2/2
    • Carefully lift each speaker from the housing. It may be necessary to break a light adhesive seal.
    • Be aware of the two wires that are connected to each speaker.
    • Set each speaker beside the main housing.
  11. Monster Soundstage S2 Front Speakers Replacement: 11 단계, 이미지 1/3 Monster Soundstage S2 Front Speakers Replacement: 11 단계, 이미지 2/3 Monster Soundstage S2 Front Speakers Replacement: 11 단계, 이미지 3/3
    • Carefully but firmly unplug the two wires from each driver.
    • The front speakers can now be removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Josue A Melgar
회원 가입일: 01/27/17
116 평판
안내서 1개 작성함
Cal Poly, Team 21-5, Maness Winter 2017 Cal Poly, Team 21-5, Maness Winter 2017 회원
CPSU-MANESS-W17S21G5
4 회원들
안내서 12개 작성하였습니다
댓글 한 개
Does anybody know what size driver the rear woofer is and resistance, would like to repair an s3 for a friend in cuba who received a used one as a gift
Matt Gould - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 333
