주요 콘텐츠로 건너뛰기
Montgomery Ward GEN-39500 Antenna Replacement
필요한 것
  1. Montgomery Ward GEN-39500 Antenna Replacement, Back Cover: 1 단계, 이미지 1/1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Antenna Replacement: 2 단계, 이미지 1/1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Antenna Replacement: 3 단계, 이미지 1/2 Montgomery Ward GEN-39500 Antenna Replacement: 3 단계, 이미지 2/2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Antenna Replacement, Antenna: 4 단계, 이미지 1/2 Montgomery Ward GEN-39500 Antenna Replacement, Antenna: 4 단계, 이미지 2/2
    • Unsolder the wire connecting the antenna to the radio.
  5. Montgomery Ward GEN-39500 Antenna Replacement: 5 단계, 이미지 1/1
    • Tilt the back cover up and remove the two 7.5 mm Phillips screws holding the antenna in place.
  6. Montgomery Ward GEN-39500 Antenna Replacement: 6 단계, 이미지 1/1
    • Remove the antenna.
결론
Dustin Platt
회원 가입일: 04/01/15
931 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G5
4 회원들
안내서 13개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 122
