주요 콘텐츠로 건너뛰기
Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side)
필요한 것
  1. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side), Back Cover: 1 단계, 이미지 1/1
    • Remove the nine 35 mm Phillips screws securing the back cover of the case.
  2. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 2 단계, 이미지 1/1
    • Carefully remove the back cover.
    • Soldered wires connect electronics on the back cover to the internal electronics. Be careful not to break any connections.
  3. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 3 단계, 이미지 1/2 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 3 단계, 이미지 2/2
    • Unplug the black and yellow wires connecting the power supply unit to the rest of the electronics:
    • This is not necessarily required. This step is to allow the back cover more movement as you work on the inside of the unit.
  4. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side), Cassette Player (Left Side): 4 단계, 이미지 1/1
    • Remove the following 6 screws:
    • Four 25 mm Phillips
    • Two 2.5 mm Flathead
  5. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 5 단계, 이미지 1/1
    • Remove the small steel plate on the right-hand side.
  6. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 6 단계, 이미지 1/1
    • Move the brass plate with attached pneumatic cylinder on the left-hand side.
    • Detach the plate at the pneumatic cylinder and leave the plate attached to the torsional spring.
  7. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 7 단계, 이미지 1/3 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 7 단계, 이미지 2/3 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 7 단계, 이미지 3/3
    • Stand the unit up and press eject to open the door on the cassette player.
    • Gripping the cassette player from the back, lift upwards on the door to unclip it from the bar around which it rotates. This may take some effort.
  8. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 8 단계, 이미지 1/1
    • Remove the 5 mm Phillips screw holding the blue and yellow wires in place.
  9. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 9 단계, 이미지 1/3 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 9 단계, 이미지 2/3 Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 9 단계, 이미지 3/3
    • Unsolder the red and white wires leading from the cassette player unit.
  10. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 10 단계, 이미지 1/1
    • Unplug the grey wire leading from the cassette player.
  11. Montgomery Ward GEN-39500 Cassette Player Replacement (Left Side): 11 단계, 이미지 1/1
    • Remove the cassette player.
결론
Dustin Platt
회원 가입일: 04/01/15
931 평판
안내서 6개 작성하였습니다
Cal Poly, Team 12-5, Lancaster Spring 2015 Cal Poly, Team 12-5, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G5
4 회원들
안내서 13개 작성하였습니다
0 댓글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 185
