주요 콘텐츠로 건너뛰기
Moosoo XL-618A HEPA Filter Replacement
  1. Moosoo XL-618A HEPA Filter Replacement, Microscreen Filter: 1 단계, 이미지 2개 중 1개 Moosoo XL-618A HEPA Filter Replacement, Microscreen Filter: 1 단계, 이미지 2개 중 2개
    • Press the blue button on the exterior of the device to open the hatch.
    • If the seal contains debris or trash, be sure to hold it over a garbage can.
  2. Moosoo XL-618A HEPA Filter Replacement: 2 단계, 이미지 2개 중 1개 Moosoo XL-618A HEPA Filter Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the microscreen filter by twisting it to the left and pulling it out.
    • Don't be alarmed if both filters come out together; the HEPA filter comes out very easily.
  3. Moosoo XL-618A HEPA Filter Replacement, HEPA Filter: 3 단계, 이미지 2개 중 1개 Moosoo XL-618A HEPA Filter Replacement, HEPA Filter: 3 단계, 이미지 2개 중 2개
    • Pull the orange HEPA filter out.
    • When you reassemble the device, make sure the black ring on the filter is facing you.
    • The device comes with a replacement filter. However, you can buy more as needed.
결론
작성자
4다른 기여자 명과 함께
Ashtyn
회원 가입일: 09/20/23
507 평판
안내서 3개를 작성함
Utah Tech University, Team 1-1, McMurrin Fall 2023 Utah Tech University, Team 1-1, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G1
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 43
전체 시간: 672
