주요 콘텐츠로 건너뛰기
Moosoo XL-618A HEPA Filter Replacement
  1. Moosoo XL-618A HEPA Filter Replacement, Microscreen Filter: 1 단계, 이미지 1/2 Moosoo XL-618A HEPA Filter Replacement, Microscreen Filter: 1 단계, 이미지 2/2
    • Press the blue button on the exterior of the device to open the hatch.
    • If the seal contains debris or trash, be sure to hold it over a garbage can.
  2. Moosoo XL-618A HEPA Filter Replacement: 2 단계, 이미지 1/2 Moosoo XL-618A HEPA Filter Replacement: 2 단계, 이미지 2/2
    • Remove the microscreen filter by twisting it to the left and pulling it out.
    • Don't be alarmed if both filters come out together; the HEPA filter comes out very easily.
  3. Moosoo XL-618A HEPA Filter Replacement, HEPA Filter: 3 단계, 이미지 1/2 Moosoo XL-618A HEPA Filter Replacement, HEPA Filter: 3 단계, 이미지 2/2
    • Pull the orange HEPA filter out.
    • When you reassemble the device, make sure the black ring on the filter is facing you.
    • The device comes with a replacement filter. However, you can buy more as needed.
결론
Ashtyn
회원 가입일: 09/20/23
489 평판
안내서 3개 작성하였습니다
Utah Tech University, Team 1-1, McMurrin Fall 2023 Utah Tech University, Team 1-1, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 204
