주요 콘텐츠로 건너뛰기
Moosoo XL-618A Motherboard Replacement
필요한 것
  1. Moosoo XL-618A Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Moosoo XL-618A Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Remove all nine 16 mm screws from the top motor with the Phillips #1 screwdriver.
  2. Moosoo XL-618A Motherboard Replacement: 2 단계, 이미지 1/2 Moosoo XL-618A Motherboard Replacement: 2 단계, 이미지 2/2
    • Using a spudger, open the device along the small lines that are visible to you. Go on to pry off all other detachable objects and set aside.
    • Make sure to not go too far as this could further damage the device.
  3. Moosoo XL-618A Motherboard Replacement: 3 단계, 이미지 1/1
    • Pull the motherboard underneath the top handle of the top motor out and remove the connected wires. Then replace it with a new motherboard.
    • Be careful with the wires so that they don't get damaged in the process.
결론
Ashtyn
회원 가입일: 09/20/23
489 평판
안내서 3개 작성하였습니다
Utah Tech University, Team 1-1, McMurrin Fall 2023 Utah Tech University, Team 1-1, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 23
30일 전: 82
전체 시간: 335
