주요 콘텐츠로 건너뛰기
Moosoo XL-618A Motherboard Replacement
필요한 것
  1. Moosoo XL-618A Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Moosoo XL-618A Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Remove all nine 16 mm screws from the top motor with the Phillips #1 screwdriver.
  2. Moosoo XL-618A Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Moosoo XL-618A Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Using a spudger, open the device along the small lines that are visible to you. Go on to pry off all other detachable objects and set aside.
    • Make sure to not go too far as this could further damage the device.
  3. Moosoo XL-618A Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Pull the motherboard underneath the top handle of the top motor out and remove the connected wires. Then replace it with a new motherboard.
    • Be careful with the wires so that they don't get damaged in the process.
결론
작성자
4다른 기여자 명과 함께
Ashtyn
회원 가입일: 09/20/23
507 평판
안내서 3개를 작성함
Utah Tech University, Team 1-1, McMurrin Fall 2023 Utah Tech University, Team 1-1, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G1
3 회원들
안내서 6개를 작성함
1가이드 댓글
I can't for the life of me get the power lever to go back in!!! Any suggestions??
Odee56 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 13
지난 30일: 57
전체 시간: 1,270
