주요 콘텐츠로 건너뛰기
Moosoo XL-618A Motor Replacement
필요한 것
  1. Moosoo XL-618A Motor Replacement, Motor: 1 단계, 이미지 1개 중 1개
    • Remove the eight 11 mm screws on the bottom of the vacuum with the Phillips #1 screwdriver.
  2. Moosoo XL-618A Motor Replacement: 2 단계, 이미지 3개 중 1개 Moosoo XL-618A Motor Replacement: 2 단계, 이미지 3개 중 2개 Moosoo XL-618A Motor Replacement: 2 단계, 이미지 3개 중 3개
    • Pull the two hard plastic covers off of the floor brush piece.
  3. Moosoo XL-618A Motor Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the 9 mm screw to the motor with the Phillips #1 screwdriver.
  4. Moosoo XL-618A Motor Replacement: 4 단계, 이미지 3개 중 1개 Moosoo XL-618A Motor Replacement: 4 단계, 이미지 3개 중 2개 Moosoo XL-618A Motor Replacement: 4 단계, 이미지 3개 중 3개
    • Take the motor and floor brush out of their slot and pull the floor brush off of the motor.
    • This is the perfect opportunity to clean the brush as well.
  5. Moosoo XL-618A Motor Replacement: 5 단계, 이미지 3개 중 1개 Moosoo XL-618A Motor Replacement: 5 단계, 이미지 3개 중 2개 Moosoo XL-618A Motor Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the two 9 mm screws with the Phillips #1 screwdriver and pull the plastic piece off of the motor.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Ashtyn
회원 가입일: 09/20/23
507 평판
안내서 3개를 작성함
Utah Tech University, Team 1-1, McMurrin Fall 2023 Utah Tech University, Team 1-1, McMurrin Fall 2023 회원
UTAHTECH-MCMURRIN-F23S1G1
3 회원들
안내서 6개를 작성함
1가이드 댓글
Thank you what a huge help you've been plus I believe you saved me money because I was at the point of giving up until I found this. Bless you, and Happy Holidays to you and your family. Cheers! Sincerely
, Duke G.
Duke Gibo - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 50
전체 시간: 1,052
