분해도
해당 분해도는 수리 안내서가 아닙니다. Morphy Richards Iron 수리는 저희 서비스 설명서를 사용하십시오.
This is the iron we will take apart.
First remove the rear or the iron using the flathead screwdriver.
Next remove the cable bridge bracket.
Next remove the screws from the base. (see arrows for location)
Next remove the screw the hold the top on.
To free the long cable remove from terminal block at rear.
At the front of the iron pull out the buttons for the steam and water.
Next unclip the button holder (red circle) by undoing the screws (black circle)
Next remove the bridge clip from the arrows position.
Next remove the inner button (black circle)
Now remove the centre screw (red arrow)
slide off the cable holder from the cable.
Disassemble the plug
First remove the casing.
Now remove the wires from the pins.
Next remove the pins.
Remove front of the iron by undoing the screw (arrow) by first taking off cover cap.
Next take out round selector, this is simply clipped so can be pulled out with pliers.
Next remove the washer parts at the front of the iron.
Take the tubing off.
Remove the seals for the water pump.
Now take pumps out.
Remove the screw (circled) this will lead to the separation of the base and the top.
Remove the top of the iron to reveal the under parts.
Now remove the rubber seals from the plate.
Take out the screws linking to the stainless steel base.
Remove the terminal block from the wires.
Next take off the black section of the iron.
Now remove the screws from the steel base.
Next remove each individual part ( mostly wiring)
All parts at the end of the process.
다른 기여자 2명과 함께
회원 가입일: 03/17/10
269 평판
안내서 1개 작성함
배지: 0
해당 안내서를 사이트/포럼에 작은 위젯으로 포함하려면 크기를 선택하고 아래 코드를 복사하십시오.
24 시간 전: 5
7일 전: 38
30일 전: 127
전체 시간: 32,548
