주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mortise Lock Replacement
필요한 것
  1. Mortise Lock Replacement, Unscrew the Door Handle: 1 단계, 이미지 2개 중 1개 Mortise Lock Replacement, Unscrew the Door Handle: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • Unscrew the set screw holding the door handle using a 3mm hex key.
    • Some security doors might not have a set screw and instead require you to remove the whole faceplate.
  2. Mortise Lock Replacement, Remove the Handles: 2 단계, 이미지 2개 중 1개 Mortise Lock Replacement, Remove the Handles: 2 단계, 이미지 2개 중 2개
    • Remove both handles by pulling them out of the lock.
    • Take care not to lose the little plastic rings. They act as a bearing, ensuring that turning the door handle feels easy and smooth.
    • Some special doors, such as fire doors or steel doors, will require you to remove the faceplate in order to remove the lock, as with these, it mounts through the lock body.
  3. Mortise Lock Replacement, Remove the Lock: 3 단계, 이미지 1개 중 1개
    • Should you have a cylinder installed, you will have to take it out before you can remove the lock.
    • Remove the two screws securing the lock to the doorframe.
    • Pull the lock out towards you.
결론
작성자
1다른 기여자 명과 함께
Sebastian
회원 가입일: 08/19/18
33,122 평판
안내서 72개를 작성함
German Translators German Translators 회원
Community
50 회원들
안내서 1,584개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 74
전체 시간: 1,471
