주요 콘텐츠로 건너뛰기
Motion Computing LE1600 Battery Replacement
  1. Motion Computing LE1600 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device so the screen is facing down.
  2. Motion Computing LE1600 Battery Replacement: 2 단계, 이미지 1/2 Motion Computing LE1600 Battery Replacement: 2 단계, 이미지 2/2
    • Slide the battery lock switch next to the power slider to the unlocked position.
  3. Motion Computing LE1600 Battery Replacement: 3 단계, 이미지 1/3 Motion Computing LE1600 Battery Replacement: 3 단계, 이미지 2/3 Motion Computing LE1600 Battery Replacement: 3 단계, 이미지 3/3
    • Slide and hold the switch by the fan vent to the unlocked position. Firmly grasp the battery and pull away from tablet.
    • When replacing the battery, place the end near the fan vent in first. Make sure to keep the other switch in the unlocked position while pushing the battery into place.
결론
David Troy
회원 가입일: 04/04/12
44 평판
안내서 3개 작성하였습니다
Cal Poly, Team 15-14, Forte Spring 2012 Cal Poly, Team 15-14, Forte Spring 2012 회원
CPSU-FORTE-S12S15G14
5 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 9
30일 전: 22
전체 시간: 2,743
