소개
Use this guide to remove and replace a worn out battery in the Motorola Moto C Plus.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
필요한 것
Insert a thumbnail, or spudger, into the notch on the bottom right to start separating the phone unit from the back cover.
Move to the bottom left corner and pry the phone unit out of the back cover until you can get a good grip.
Use a spudger or fingernail to lift the battery starting at the notch on the bottom left.
Lever the battery out of its recess and remove it.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
다른 한 분이 해당 안내서를 완성하였습니다.
