주요 콘텐츠로 건너뛰기
Moto G4 LCD Screen and Digitizer Assembly Replacement
필요한 것
  1. Moto G4 LCD Screen and Digitizer Assembly Replacement, Back Cover: 1 단계, 이미지 1/3 Moto G4 LCD Screen and Digitizer Assembly Replacement, Back Cover: 1 단계, 이미지 2/3 Moto G4 LCD Screen and Digitizer Assembly Replacement, Back Cover: 1 단계, 이미지 3/3
    • Insert a fingernail or a spudger into the notch on the bottom edge of the phone, near the charge port.
    • Gently twist or pry to open a small gap between the back cover and the body of the phone.
    • While keeping your tool (or fingernail) inserted into the gap between the back cover and the body of the phone, slide it around the corner to begin loosening the plastic clips holding the cover in place.
  2. Moto G4 LCD Screen and Digitizer Assembly Replacement: 2 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 2 단계, 이미지 2/2
    • Slide your tool all along the side of the phone to separate more of the clips securing the back cover.
  3. Moto G4 LCD Screen and Digitizer Assembly Replacement: 3 단계, 이미지 1/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 3 단계, 이미지 2/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 3 단계, 이미지 3/3
    • Keep your tool inserted slightly under the back cover, and slide it around the top corner.
    • If necessary, continue prying around the remaining edges of the phone until the back cover comes free.
  4. Moto G4 LCD Screen and Digitizer Assembly Replacement: 4 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the back cover.
    • To install the back cover, carefully position it over the phone and then press gently all around the edges until you feel the clips snap into place.
  5. Moto G4 LCD Screen and Digitizer Assembly Replacement, Midframe: 5 단계, 이미지 1/3 Moto G4 LCD Screen and Digitizer Assembly Replacement, Midframe: 5 단계, 이미지 2/3 Moto G4 LCD Screen and Digitizer Assembly Replacement, Midframe: 5 단계, 이미지 3/3
    • Push to eject and remove the MicroSD and SIM cards (if installed).
  6. Moto G4 LCD Screen and Digitizer Assembly Replacement: 6 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 6 단계, 이미지 2/2
    • Use a spudger to pry up the rubber cover for the camera flash connector.
  7. Moto G4 LCD Screen and Digitizer Assembly Replacement: 7 단계, 이미지 1/1
    • Remove the rubber cover.
  8. Moto G4 LCD Screen and Digitizer Assembly Replacement: 8 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 8 단계, 이미지 2/2
    • Use a spudger to disconnect the camera flash connector by prying it straight up.
  9. Moto G4 LCD Screen and Digitizer Assembly Replacement: 9 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the nineteen identical 3.1 mm screws securing the midframe.
    In my kit, the T3 Torx bit came in the ‘repair part’ box, while a T5 Torx bit was in the ‘repair tools’ box.
    Joseph Albert - 답글
    my phone had t4, not t3
    Donald Smith - 답글
    Screws are stuck quite hard, apply a hefty amount of pressure when removing. Otherwise you’ll destroy the thread
    face - 답글
    unable to remove 8 of the screws. any suggestions?
    wayne malcom - 답글
    My T4 is the tool that fit. I can see why people strip these. They were dam tight for such little screws.
    I also had a tough time getting them out of the socket once loose. Magnet in the tool was not very strong. I used my tweezers, and scratch the screw heads. That means they are real soft steel, and strip easy.
    P 38 - 답글
  10. Moto G4 LCD Screen and Digitizer Assembly Replacement: 10 단계, 이미지 1/1
    • Insert a spudger under the midframe at the top left corner, and gently twist to separate it from the body of the phone.
    I couldn’t get the spudger in, but had success with the opening pick instead.
    Bernd Mast - 답글
  11. Moto G4 LCD Screen and Digitizer Assembly Replacement: 11 단계, 이미지 1/1
    • Remove the midframe.
    During the midframe removal, be careful and do not put too much torsional stress on the loudspeaker pickup wires (to the right of the main camera). It’s not that difficult to crush or shear the pickups there. Doing so will render your phone silent.
    Kevin Kwan - 답글
    Exactly what happened to me. Both contacts broke off and if just loosely put where they were, they can't make proper contact anymore.
    There should be a warning about this in the guide itself!
    Simon Vetter -
  12. Moto G4 LCD Screen and Digitizer Assembly Replacement, Battery: 12 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement, Battery: 12 단계, 이미지 2/2
    • Peel up and remove any tape connecting the battery to the main board.
    • Be very careful not to puncture the battery with any sharp tools. A damaged lithium-ion battery can catch fire and/or explode.
  13. Moto G4 LCD Screen and Digitizer Assembly Replacement: 13 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 13 단계, 이미지 2/2
    • Insert a thin tool (such as one of your tweezer tips) under the red and black battery wires, and slide it underneath the battery connector.
    • Gently pry straight up to disconnect the battery.
    • Pry only from the side where the wires attach to the connector—if you pry anywhere else, you may break the socket.
    • During reassembly, align the connector in its socket with the exposed copper wire facing up, and then press straight down to reconnect it, wiggling slightly as you press to help it seat correctly.
    Before detaching the connector, you may want to take a photo to remember which way the red and black wires go. Mine were the same way as in this photo, but when looking at the tiny connector of the replacement battery it wasn’t easy to be sure which way to insert it.
    jouniseppanen - 답글
    What can you do if you break the socket??? Will anyone email me an idea, Or- is it simply ruined-??? My email address is jeffrey_f4@yahoo.com. THANKS in advance, IF- anyone will take the time to email me about this-!!!!!!!! :)
    Jeff Farmer - 답글
    So you have bare copper wires and you’re sticking a metal tip tweezer in the vicinity.
    And yes, the battery is discharged as far as you can, but,………
    Maybe an idea to snip the wires somewhere further up before doing this ?
    Gary Jones - 답글
  14. Moto G4 LCD Screen and Digitizer Assembly Replacement: 14 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 14 단계, 이미지 2/2
    • Push the battery wires towards the battery to de-route them from the black bracket on the motherboard.
  15. Moto G4 LCD Screen and Digitizer Assembly Replacement: 15 단계, 이미지 1/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 15 단계, 이미지 2/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 15 단계, 이미지 3/3
    • Peel up the black pull tab at the top of the battery, and pull slowly but firmly to separate the battery from the adhesive holding it in place.
    • The battery separates more easily if you add a few drops of isopropyl alcohol along each side, to soften the adhesive beneath. High concentration (90% or greater) alcohol will not harm your phone's components.
    • Heating the area behind the battery can also help soften the adhesive, but be very careful not to overheat the battery.
    • If the pull tab breaks, use a spudger or an old credit card to pry up carefully on the edges of the battery until it comes loose.
    • Don't deform or puncture the battery—it can catch fire and/or explode if damaged.
    • Never reinstall a damaged or deformed battery. Replace the battery.
  16. Moto G4 LCD Screen and Digitizer Assembly Replacement: 16 단계, 이미지 1/1
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Remove the battery.
    • During installation, note the orientation of the battery—if the connector is on the same side as the motherboard, and the text is upside-down relative to the rest of the phone, you've done it correctly.
    • Use a few strips of thin double-sided adhesive tape or a pre-cut adhesive card to secure the battery. (Or, if you are replacing the display, it may come with adhesive for the battery pre-installed.)
  17. Moto G4 LCD Screen and Digitizer Assembly Replacement, LCD Screen and Digitizer Assembly: 17 단계, 이미지 1/1
    • Peel up and remove the black rubber cover from the charging port and vibration motor connector.
  18. Moto G4 LCD Screen and Digitizer Assembly Replacement: 18 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 18 단계, 이미지 2/2
    • Insert the point of your spudger underneath the vibration motor, and gently pry up to separate it from the frame.
    • You don't need to completely detach the vibration motor; it can stay wired to the motherboard.
  19. Moto G4 LCD Screen and Digitizer Assembly Replacement: 19 단계, 이미지 1/1
    • Peel up the copper tape covering the display connector.
    • This tape provides protection from electromagnetic interference. Keep it in one piece if possible, and carefully fold it back into position when your repair is complete.
  20. Moto G4 LCD Screen and Digitizer Assembly Replacement: 20 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 20 단계, 이미지 2/2
    • Use your spudger to disconnect the display by prying its connector straight up from the motherboard, on the edge nearest the side of the phone.
  21. Moto G4 LCD Screen and Digitizer Assembly Replacement: 21 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 21 단계, 이미지 2/2
    • Pry up with your spudger to flip open the locking flap on the headphone jack's ZIF connector.
    • It's possible to disconnect the headphone jack at this point by pulling its orange flex cable straight out of the ZIF socket, but it's easy to tear the cable if you're not careful. For a better method, continue with the steps below.
    The orange flex cable is glued to the motherboard at the ‘A’ mark on the corner. Make sure to pry them apart before trying to remove the motherboard or pull the cable out of the ZIF socket.
    Donald Diviney - 답글
  22. Moto G4 LCD Screen and Digitizer Assembly Replacement: 22 단계, 이미지 1/1
    • Use a T3 Torx driver to remove the two bronze-colored, 2.4 mm screws securing the motherboard.
  23. Moto G4 LCD Screen and Digitizer Assembly Replacement: 23 단계, 이미지 1/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 23 단계, 이미지 2/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 23 단계, 이미지 3/3
    • Grasping the motherboard by its edges, left the bottom end up at an angle, while keeping the top edge close to the phone.
    • Use your spudger to pry up the front-facing camera and make sure it separates safely from the frame. The camera can remain attached to the motherboard.
    • Using your tweezers, grasp the headphone jack flex cable and carefully pull it out of its socket as you remove the motherboard.
    • Remove the motherboard.
    • If you feel any resistance, stop. Make sure there are no components still holding the frame to the motherboard.
  24. Moto G4 LCD Screen and Digitizer Assembly Replacement: 24 단계, 이미지 1/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 24 단계, 이미지 2/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 24 단계, 이미지 3/3
    • Insert the point of your spudger into the headphone port, and pry straight up to separate the headphone jack from the frame.
    • If needed, pry from the opposite side of the headphone jack to finish separating it.
  25. Moto G4 LCD Screen and Digitizer Assembly Replacement: 25 단계, 이미지 1/1
    • Remove the headphone jack.
  26. Moto G4 LCD Screen and Digitizer Assembly Replacement: 26 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 26 단계, 이미지 2/2
    • Using the flat of your spudger, pry up on the upper right edge of the earpiece speaker to separate it from the frame.
    • Strong adhesive secures the earpiece speaker. If necessary, apply heat or a few drops of isopropyl alcohol to help weaken the adhesive and make it easier to remove.
    Bei meinem verschickten iFixit Ersatzteil war der Lautsprecher schon drinnen - ich musste ihn also nicht aus dem alten Teil herausnehmen.
    Matthias Uiberacker - 답글
  27. Moto G4 LCD Screen and Digitizer Assembly Replacement: 27 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 27 단계, 이미지 2/2
    • Remove the earpiece speaker.
    • Check the condition of the adhesive around the bottom of the earpiece speaker when you reinstall it. A little heat from a hair dryer or iOpener can help soften the adhesive and make it sticky again. Be careful not to touch or damage the surface of the speaker.
    • In some of the previous photos in this guide, the speaker is shown installed incorrectly. During installation, make sure the speaker's two spring contacts are located at the bottom corners, as shown in the first image in this step. Images showing the speaker rotated 180° (with the spring contacts near the top edge of the phone) are incorrect.
  28. Moto G4 LCD Screen and Digitizer Assembly Replacement: 28 단계, 이미지 1/2 Moto G4 LCD Screen and Digitizer Assembly Replacement: 28 단계, 이미지 2/2
    • Wedge the sharp edge of your iFixit opening tool between the headphone jack flex and the plastic frame it's adhered to.
    • Carefully press down to separate the headphone jack flex cable from the adhesive securing it.
    • Don't use too much force, or you may damage the flex cable. If necessary, apply heat or a few drops of isopropyl alcohol to help weaken the adhesive and make it easier to remove.
    Achtung! Das Bild ist leicht irreführend, da das Öffnungswerkzeug hier direkt beim Flachbandkabel ansetzt. Das Flachbandkabel sitzt aber noch auf einem weißen Plastikplättchen, welches dann am Gehäuse klebt. Die Klebung zwischen Flachbandkabel und Plättchen ist kaum zu lösen und soll auch nicht gelöst werden. Das Plastikplättchen muss vom Gehäuse gelöst werden. So kann man das Flachbandkabel samt Plastikplättchen gut herausbekommen.
  29. Moto G4 LCD Screen and Digitizer Assembly Replacement: 29 단계, 이미지 1/1
    • Remove the headphone jack flex cable.
  30. Moto G4 LCD Screen and Digitizer Assembly Replacement: 30 단계, 이미지 1/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 30 단계, 이미지 2/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 30 단계, 이미지 3/3
    • The two case buttons (power and volume rocker) are each secured with two mushroom-shaped pins.
    • In the following steps, you'll apply pressure to these pins from the inside in order to remove and transfer the buttons.
  31. Moto G4 LCD Screen and Digitizer Assembly Replacement: 31 단계, 이미지 1/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 31 단계, 이미지 2/3 Moto G4 LCD Screen and Digitizer Assembly Replacement: 31 단계, 이미지 3/3
    • Push the power button out of the frame from the inside by carefully pressing the tip of your spudger against the tops of the two mushroom pins securing it.
  32. Moto G4 LCD Screen and Digitizer Assembly Replacement: 32 단계, 이미지 1/1
    • Repeat the previous step to push the volume rocker button out of the frame.
    • During reassembly, press the buttons gently into the frame in the orientation shown here.
  33. Moto G4 LCD Screen and Digitizer Assembly Replacement: 33 단계, 이미지 1/1
    • Only the LCD screen and digitizer assembly (with frame) remains.
    • Check carefully to make sure your replacement part matches, and that you've removed all the necessary parts from the old frame for installation in the new one.
    I was about to order the replacement screen from ifixit but I notice that the phone I want to fix does not a volume rocker switch but two separate switches - one for volume up and a separate one for volume down. The model number is Moto G4 and the SKU is XT1622. Can I still buy the replacement screen from ifixit?
    Graham Gullett - 답글
결론
Carefully compare your new replacement part to the original part. Remove any adhesive backings before installing your new battery.
다른 10명이 해당 안내서를 완성하였습니다.
Jeff Suovanen
회원 가입일: 08/06/13
428,098 평판
안내서 259개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 2개
I would not recommend it. The adhesive between the screen and the frame was too strong for me to separate, so a screen with a new frame pre-installed would be a better bet.
I used this:
https://www.ebay.com/itm/OEM-Motorola-Mo...
John Smith -
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 23
전체 시간: 6,659
