주요 콘텐츠로 건너뛰기
Moto G6 Plus SIM Card Tray Replacement
필요한 것
  1. Moto G6 Plus SIM Card Tray Replacement, Remove the SIM card tray: 1 단계, 이미지 1/2 Moto G6 Plus SIM Card Tray Replacement, Remove the SIM card tray: 1 단계, 이미지 2/2
    • Insert a paperclip or SIM card eject tool into the small hole in the SIM card tray on the right side of the top edge of the phone.
    • Press the tool into the hole to eject the tray.
    • This may require a significant amount of force.
    • The ejection mechanism is deeper in this phone than others and may require a longer SIM card eject tool. If your tool isn't long enough to reach the mechanism, try using an unfolded paperclip instead.
  2. Moto G6 Plus SIM Card Tray Replacement: 2 단계, 이미지 1/1
    • Remove the SIM card tray.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Adam O'Camb
회원 가입일: 04/11/15
196,299 평판
안내서 416개 작성하였습니다
댓글 2개
Thanks. Your advice on using considerable force worked perfectly!
Piers Spencer - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 952
