주요 콘텐츠로 건너뛰기
Moto X Pure Edition Auxiliary Port Replacement
필요한 것
  1. Moto X Pure Edition Auxiliary Port Replacement, Opening Procedure: 1 단계, 이미지 1/1
    • Prepare an iOpener and heat the back of the phone along its right edge for about five minutes. This will help soften the adhesive securing the back cover.
    • You may need to reheat and reapply the iOpener several times to get the phone warm enough. Follow the iOpener instructions to avoid overheating.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the phone—the LCD display and internal battery are both susceptible to heat damage.
  2. Moto X Pure Edition Auxiliary Port Replacement: 2 단계, 이미지 1/3 Moto X Pure Edition Auxiliary Port Replacement: 2 단계, 이미지 2/3 Moto X Pure Edition Auxiliary Port Replacement: 2 단계, 이미지 3/3
    • In the following steps, you'll be cutting through the adhesive securing the back cover.
    • The adhesive is laid out as seen in the first image, which shows the inside of the cover.
    • Avoid slicing in this area to avoid damaging delicate ribbon cables.
  3. Moto X Pure Edition Auxiliary Port Replacement: 3 단계, 이미지 1/3 Moto X Pure Edition Auxiliary Port Replacement: 3 단계, 이미지 2/3 Moto X Pure Edition Auxiliary Port Replacement: 3 단계, 이미지 3/3
    • Hold a pair of pointed tweezers closed, and insert them into the small hole on the edge of the back cover near the SIM card slot.
    • Use the tweezers to lift the cover up slightly, and slide an opening pick into the gap between the cover and the frame.
    Insert only one of the tweezers’ point into the hole. Once the rubber backing is lifted high enough, slip a corner of the opening pick under the rubber backing. Leave the first pick near the corner while you use a second pick as directed in Step 6.
    Levi Asuncion - 답글
  4. Moto X Pure Edition Auxiliary Port Replacement: 4 단계, 이미지 1/3 Moto X Pure Edition Auxiliary Port Replacement: 4 단계, 이미지 2/3 Moto X Pure Edition Auxiliary Port Replacement: 4 단계, 이미지 3/3
    • Slide the opening pick along the edge of the phone to slice through the back cover adhesive.
    • Try to insert the pick as far as you can underneath the cover, toward the center of the cover. There's thick adhesive on the middle of the cover that must be separated.
    • Leave the pick in place as you proceed to the next step. Leaving the pick inserted can help prevent the glue you just separated from re-adhering.
    I did not have a pick, used a few old credit cards, leaving them in place to keep the phone back separated.
    Used a hair dryer to heat up a little, one section at a time, was enough to remove. Pulled apart slowly.
    Left adhesive on the back and on the phone, where possible, using a tiny screw driver to separate. Reused whatever adhesive remained to reattach.
    Natalie Hursky - 답글
  5. Moto X Pure Edition Auxiliary Port Replacement: 5 단계, 이미지 1/1
    • Prepare an iOpener and heat the back of the phone along its left edge for about five minutes. This will help soften the adhesive securing the rest of the back cover.
  6. Moto X Pure Edition Auxiliary Port Replacement: 6 단계, 이미지 1/2 Moto X Pure Edition Auxiliary Port Replacement: 6 단계, 이미지 2/2
    • Slice through the adhesive along the bottom edge of the phone.
    • Re-heat the back cover as needed to prevent the glue from cooling and hardening.
  7. Moto X Pure Edition Auxiliary Port Replacement: 7 단계, 이미지 1/2 Moto X Pure Edition Auxiliary Port Replacement: 7 단계, 이미지 2/2
    • Slice through the adhesive along the left side of the phone.
    • Stop cutting when you get to the edge of the volume buttons. Cutting past this point may damage the ribbon cables underneath the cover.
  8. Moto X Pure Edition Auxiliary Port Replacement: 8 단계, 이미지 1/3 Moto X Pure Edition Auxiliary Port Replacement: 8 단계, 이미지 2/3 Moto X Pure Edition Auxiliary Port Replacement: 8 단계, 이미지 3/3
    • Slice through the adhesive along the top edge of the phone, pulling the pick out slightly to guide it around the rear-facing camera.
  9. Moto X Pure Edition Auxiliary Port Replacement: 9 단계, 이미지 1/3 Moto X Pure Edition Auxiliary Port Replacement: 9 단계, 이미지 2/3 Moto X Pure Edition Auxiliary Port Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $5.99
    구매
    • Carefully pry the cover away from the phone.
    • This may take a lot of force if the adhesive in the middle is still attached. As you lift the cover, you may need to use an opening pick to slice through any remaining adhesive.
    • To reinstall the back cover:
    • First use tweezers and a spudger to peel and scrape away any remaining adhesive from both the back cover and the phone's chassis.
    • Then, clean the adhesion areas with high concentration isopropyl alcohol (at least 90%) and a lint-free cloth. Swipe in one direction only, not back and forth. This will help prep the surface for the new adhesive.
    • Replacement adhesive comes in a pre-cut sheet to match the exact contours of the back cover. If that's not available, you can use a high-bond double-sided tape, such as Tesa 61395. Before installing the precut adhesive on the back cover, remove the metal insert. Install the adhesive, then replace the insert.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond.
    • If desired, you may reinstall the back cover without replacing the adhesive. Remove any large chunks of adhesive that might prevent the back cover from sitting down flush. After installation, heat the back cover and apply pressure to secure it.
    Had the pre-cut adhesive sheet for reinstalling the Moto X Pure’s back cover. It seemed like the most “original” option at the time. I tried and tried to get it aligned inside the back cover, but found it virtually impossible to do. You pretty much have to get it perfectly aligned and then stick it down all at once. If it makes contact with the cover before it’s perfectly aligned, it’s all over. You’ll never get it back off without destroying it.
    After failing with the pre-cut sheet, I resorted to the die-cut strips and corner pieces. This worked just fine.
    Jeff Carleton - 답글
  10. Moto X Pure Edition Auxiliary Port Replacement: 10 단계, 이미지 1/3 Moto X Pure Edition Auxiliary Port Replacement: 10 단계, 이미지 2/3 Moto X Pure Edition Auxiliary Port Replacement: 10 단계, 이미지 3/3
    • Use the point of a spudger to pry up the rubber cover over the battery connector.
    • Remove the rubber cover.
  11. Moto X Pure Edition Auxiliary Port Replacement: 11 단계, 이미지 1/2 Moto X Pure Edition Auxiliary Port Replacement: 11 단계, 이미지 2/2
    • Use the flat end of a spudger to pry the battery connector straight up and out of its socket.
    • Only pry the small tab on the end of the connector opposite the ribbon cable. Do not push against the connector too hard or you risk damaging the plug on the motherboard.
    Reconnecting the battery was difficult, did not align exactly. Note there are 2 slots that line up and 4 pins. Used a 10x magnifying lens with LED light, purchased to do this job. This step (reassembly) is where the magnifier came in handy. Had to move battery around a bit to get it to line up. Ended up removing adhesive tape from battery, so I could get in place to attach the connector. Battery held in place with screws and phone case, so far so good.
    Natalie Hursky - 답글
    this is the difficult part. I find it is easier to remove this connector as the midframe and phone screen are separating (see step 19). Be also careful in prying this mine got broken luckily it is connected to the old battery which I replaced anyway
    Neil Catalan - 답글
    Broke the battery plug right off the motherboard! Trying to do a 2nd battery replacement. Only push up gently on the edge of the tab and straight up. Shopping for a new phone.
    Natalie Hursky - 답글
  12. Moto X Pure Edition Auxiliary Port Replacement: 12 단계, 이미지 1/2 Moto X Pure Edition Auxiliary Port Replacement: 12 단계, 이미지 2/2
    • Use tweezers to lift away the rubber cover over the flash connector.
  13. Moto X Pure Edition Auxiliary Port Replacement: 13 단계, 이미지 1/2 Moto X Pure Edition Auxiliary Port Replacement: 13 단계, 이미지 2/2
    • Use the tip of a spudger against the corner of the flash connector to pry the connecter straight up and out of its socket.
  14. Moto X Pure Edition Auxiliary Port Replacement: 14 단계, 이미지 1/1
    • Use a T3 Torx driver to remove twenty 2.4 mm screws.
    Need to add a step for removing the bar holding the buttons in place. Step 5 from the tear down. Still can’t take the mid frame off though.
    Pieter Richards - 답글
    I stripped the threads on one of the 20 screws, had to drill it out. (Managed to do this without cracking the screen, completed battery replacement, all ok.)
    Careful removing the screws, be sure of tight grip. I saw T4 torx suggested on another site for Moto X Pure, this might grip better? Try both.
    Natalie Hursky - 답글
    I did not have to remove the screw holding the volume buttons bar in place. These stay attached, not needed for replacing the battery. Just the 20 screws shown.
    Natalie Hursky - 답글
    DO NOT REMOVE THE SILVER SCREW HOLDING IN THE VOLUME AND ON-OFF BUTTON. If these buttons fall out there are 4 very small springs that will pop out and are very hard to reinsert. If they do pop out do not use tweezers to reinsert but use a magnetic screw driver bit to reinsert.
    Michael Bedwell - 답글
    This is extremely easy to overlook. This screw is a different color (silver versus black) but when you’re in the swing of removing all the screws it’s tempting to just remove ALL the screws. I goofed, had the buttons fall out, could only find 3 of the springs. Put two back in the volume rocker and only one in the power button since it’s smaller, seems like it wouldn’t need two as much. Everything still works, maybe just slightly less tactile than before. Even without the the springs, there’s still some mechanical return to the buttons, so if you do lose them don’t despair.
    Michael Decker -
    This is not working, got two out. Most just strip.
    Christina Denboer - 답글
    Update. The driver provided is not the right size. I had some tools laying around and found one that fit. This allowed me to get all the screws out except the six I stripped using the driver provided by ifiixit. Turns out they come out pretty easy if you have the right size bit. Would have been an easy fix had I not bought the tools…. go figure.
    What is the right size bit?
    Marlon Nelson -
    The T3 Torx Driver was bundled in the bag with the Alcohol Prep Pad, not with the rest of the drivers! So look before you there before you call support like I did.
    pixilated1 - 답글
    T4 works better, T3 also works. Try both and proceed carefully, get a good grip before turning.
    Natalie Hursky - 답글
  15. Moto X Pure Edition Auxiliary Port Replacement: 15 단계, 이미지 1/2 Moto X Pure Edition Auxiliary Port Replacement: 15 단계, 이미지 2/2
    • Use the point of a spudger to push the small clip securing the left side of the midframe toward the edge of the phone, releasing the clip.
    On reassembly, these did not really click back in place. Held tight when reattaching the 20 (19 in my case) screws).
    Natalie Hursky - 답글
    I had to push rather hard to release both clips. The tip of the spudger bent under the pressure I had to apply. But the the clips did finally release without damage.
    Thomas Bartol - 답글
  16. Moto X Pure Edition Auxiliary Port Replacement: 16 단계, 이미지 1/1
    • Repeat the previous step to release the right side midframe clip.
  17. Moto X Pure Edition Auxiliary Port Replacement: 17 단계, 이미지 1/3 Moto X Pure Edition Auxiliary Port Replacement: 17 단계, 이미지 2/3 Moto X Pure Edition Auxiliary Port Replacement: 17 단계, 이미지 3/3
    • Holding the display by the edges, gently lift the midframe away from the display.
    • Remove the midframe from the display.
    My mid-frame and display were separated on the long sides but seemed a little bit stuck on the top and bottom. I used the flat end of the spudger to carefully pry the two assemblies apart at either end.
    Gary Herber - 답글
    In my case, stuck in the middle. Pulled apart very slowly, giving the adhesive a chance to separate, and not tearing whatever it was in there. Kept an eye on the inside middle, and very SLOW let it separate. Or was that the battery? In either case, go slow on all steps.
    Natalie Hursky - 답글
    Yeah, everything went according to the guide until this step. I lifted the midframe away from the screen assembly as shown and something in the center didn’t separate at all. I spent a good half hour terrified that I had missed a step or a screw or that there was something different about my phone. In the end I read the comments and very slowly and patiently lifted the midframe until something uncoupled and the two parts cleanly separated. I was certain that permanent damage must have been done, but upon reassembling everything seems to be working perfectly.
    Brian Horne - 답글
    Note to self - check that ALL (20) screws have been removed… especially if midframe is stubborn lifting up - i (almost) forgot about the one near the display cable (and it’s threaded into the motherboard instead of the frame) :)
    John Riselay - 답글
    In my unit, the midframe released from the display nicely just as described in the instructions.
    Thomas Bartol - 답글
  18. Moto X Pure Edition Auxiliary Port Replacement, Auxiliary Port: 18 단계, 이미지 1/1
    • Using the nylon spudger, remove the auxiliary port.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Lucas Dos Santos
회원 가입일: 03/06/16
1,053 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team 5-2, Landers Spring 2016 UMass Dartmouth, Team 5-2, Landers Spring 2016 회원
UMASSD-LANDERS-S16S5G2
3 회원들
안내서 15개 작성하였습니다
댓글 한 개
There is an extra screw that you forgot to mark for removal on the back panel of the phone, It is next to plastic cover towards the top right side of the phone.
giorgioagganis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 4,737
