이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Lay a heated iOpener on the back of the phone as shown for as least 90 seconds.
Using a pair of tweezers or your fingers, grab the black battery pull tab and slowly pull it upwards until the corner is loose.
Insert a spudger into the bottom edge of the battery and slowly pry the corner up.
Carefully swing the battery towards the right edge.
Lay the battery flat against the work surface while taking care not to strain the battery cable.
Use the point of a spudger to pry up the battery connector bracket.
Remove the battery connector bracket.
Using the point of a spudger, pry up the battery connector from its socket.
이 단계에 사용된 도구:Tesa 61395 Tape$5.99-
Remove the battery.
Remove any remaining adhesive from the phone, and clean the glued areas with isopropyl alcohol and a lint-free cloth.
Apply pre-cut adhesive strips or double-sided tape to the exposed, silver part of the battery compartment, not on the black foam layer.
Press the battery firmly into place for 5-10 seconds.
