주요 콘텐츠로 건너뛰기
필요한 것
  1. Motorola Atrix 4G Antenna Replacement, Battery: 1 단계, 이미지 1/1
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G Antenna Replacement: 2 단계, 이미지 1/2 Motorola Atrix 4G Antenna Replacement: 2 단계, 이미지 2/2
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Antenna Replacement, Antenna: 3 단계, 이미지 1/3 Motorola Atrix 4G Antenna Replacement, Antenna: 3 단계, 이미지 2/3 Motorola Atrix 4G Antenna Replacement, Antenna: 3 단계, 이미지 3/3
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G Antenna Replacement: 4 단계, 이미지 1/2 Motorola Atrix 4G Antenna Replacement: 4 단계, 이미지 2/2
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G Antenna Replacement: 5 단계, 이미지 1/2 Motorola Atrix 4G Antenna Replacement: 5 단계, 이미지 2/2
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Antenna Replacement: 6 단계, 이미지 1/1
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Antenna Replacement: 7 단계, 이미지 1/1
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G Antenna Replacement: 8 단계, 이미지 1/1
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Derek Walker
회원 가입일: 2012년 04월 19일
297 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-42, Regan Spring 2012 Cal Poly, Team 9-42, Regan Spring 2012 회원
CPSU-REGAN-S12S9G42
6 회원들
안내서 15개 작성하였습니다
0 Comments
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 12
전체 시간: 5,259
