주요 콘텐츠로 건너뛰기
Motorola Atrix 4G Bottom Speaker Replacement
필요한 것
  1. Motorola Atrix 4G Bottom Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Pry the rear cover from the back of the phone.
  2. Motorola Atrix 4G Bottom Speaker Replacement: 2 단계, 이미지 1/2 Motorola Atrix 4G Bottom Speaker Replacement: 2 단계, 이미지 2/2
    • Insert a spudger or plastic opening tool into the small notch at the base of the battery.
    • Lift the battery out of the phone.
  3. Motorola Atrix 4G Bottom Speaker Replacement, Antenna: 3 단계, 이미지 1/3 Motorola Atrix 4G Bottom Speaker Replacement, Antenna: 3 단계, 이미지 2/3 Motorola Atrix 4G Bottom Speaker Replacement, Antenna: 3 단계, 이미지 3/3
    • Remove the four 5.0 mm T5 Torx screws from the corners of the phone.
    • Remove three 5.5 mm T5 Torx screws from the back of the phone.
    • Lift up the black rubber flap near the SD card slot.
    • Remove the single 5.5 mm T5 Torx screw beneath the flap.
    • Do not attempt to loosen the screws with too much force. These screws are small, and easily stripped.
  4. Motorola Atrix 4G Bottom Speaker Replacement: 4 단계, 이미지 1/2 Motorola Atrix 4G Bottom Speaker Replacement: 4 단계, 이미지 2/2
    • Remove the back case of the phone by gently lifting the tabs located on top of the phone near the lock button.
    • Use the case opener or spudger in these small areas because the plastic tabs can be easily broken.
    • Lift the tabs located on the bottom of the phone to continue removing the back cover.
  5. Motorola Atrix 4G Bottom Speaker Replacement: 5 단계, 이미지 1/2 Motorola Atrix 4G Bottom Speaker Replacement: 5 단계, 이미지 2/2
    • Slide an opening tool between the gap from the back of the case to the front.
    • After separating the sides, make sure there is a noticeable gap between the back case and the rest of the phone.
    • After detaching the tabs and sliding down the sides, there should be a noticeable gap between the front and back cases.
  6. Motorola Atrix 4G Bottom Speaker Replacement: 6 단계, 이미지 1/1
    • Carefully separate the back case from the rest of the phone by lifting it away from the phone.
    • Do not completely remove the case from the rest of the phone. The antenna is connected to both cases.
  7. Motorola Atrix 4G Bottom Speaker Replacement: 7 단계, 이미지 1/1
    • Disconnect the antenna from its housing on the motherboard by gently lifting beneath it.
  8. Motorola Atrix 4G Bottom Speaker Replacement: 8 단계, 이미지 1/1
    • Ease the antenna from out of its guide along the side of the phone
    • Once the antenna is detached, remove the back case and the antenna from the phone
    • The antenna is soldered to the back case. Do not pull with too much force.
  9. Motorola Atrix 4G Bottom Speaker Replacement, Motherboard: 9 단계, 이미지 1/2 Motorola Atrix 4G Bottom Speaker Replacement, Motherboard: 9 단계, 이미지 2/2
    • To remove the motherboard, first dislodge the right side of the motherboard, where the external connections are located, from the rest of the phone.
    • This can be done by placing a spudger in between the two ports on the phone, between the black plastic and motherboard, and prying out.
    • The motherboard should be able to be easily lifted upwards after dislodging it.
    • If the white rubber piece moves, replace it where it came from upon reassembly.
  10. Motorola Atrix 4G Bottom Speaker Replacement: 10 단계, 이미지 1/2 Motorola Atrix 4G Bottom Speaker Replacement: 10 단계, 이미지 2/2
    • First, several connections must be disconnected to completely separate the motherboard from the rest of the phone.
    • The connection highlighted with a red box must be pulled down instead of out.
    • Using the spudger tool, separate the two connections on the motherboard highlighted with orange circles by pulling them out.
    • The black switch on top of this connection acts as a lock. Push it forwards to unlock the connection.
  11. Motorola Atrix 4G Bottom Speaker Replacement: 11 단계, 이미지 1/1
    • After disconnecting the motherboard, there should be five distinct and separate parts of the phone: back cover, back case, front case, battery, and motherboard.
  12. Motorola Atrix 4G Bottom Speaker Replacement, Bottom Speaker: 12 단계, 이미지 1/2 Motorola Atrix 4G Bottom Speaker Replacement, Bottom Speaker: 12 단계, 이미지 2/2
    • The speaker can be found on the bottom of the inside of the back case and is held in by glue.
    • Use a spudger or case opener tool to pry out the speaker by sliding it in the crack between the two pieces of black plastic.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jake
회원 가입일: 04/19/12
515 평판
안내서 2개 작성하였습니다
Cal Poly, Team 9-42, Regan Spring 2012 Cal Poly, Team 9-42, Regan Spring 2012 회원
CPSU-REGAN-S12S9G42
6 회원들
안내서 15개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 3,472
