주요 콘텐츠로 건너뛰기
Motorola Atrix HD Touchscreen and LCD Replacement
필요한 것
  1. Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola Atrix HD  Touchscreen and LCD Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before disassembling the phone, remove the SIM card and the MICRO-SD card, if equipped.
    • Begin taking apart the device by prying apart the back cover from the assembly using the plastic opening tool.
    • Continue working around the edge of the phone using the plastic opening tool.
    • When all the edges have been lifted apart, use your hands or plastic opening tool to peel the back plate from the battery. There are small adhesive strips between the back cover and the battery, so take care not to crack the back cover while prying open.
  2. Motorola Atrix HD  Touchscreen and LCD Replacement: 2 단계, 이미지 1개 중 1개
    • The adhesive strips are shown in the orange boxes. Be sure not to use too much force to pull off the back cover, or you may risk snapping the back cover.
  3. Motorola Atrix HD  Touchscreen and LCD Replacement: 3 단계, 이미지 3개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 3 단계, 이미지 3개 중 2개 Motorola Atrix HD  Touchscreen and LCD Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the red rubber screw cover with a pair of tweezers
  4. Motorola Atrix HD  Touchscreen and LCD Replacement: 4 단계, 이미지 2개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 4 단계, 이미지 2개 중 2개
    • Use the T-5 Torx bit to remove the two silver 3.3 mm screws with integrated washers.
  5. Motorola Atrix HD  Touchscreen and LCD Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the battery leads to the upward position. The ribbon cable is very thin, be gentle.
  6. Motorola Atrix HD  Touchscreen and LCD Replacement: 6 단계, 이미지 3개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 6 단계, 이미지 3개 중 2개 Motorola Atrix HD  Touchscreen and LCD Replacement: 6 단계, 이미지 3개 중 3개
    • Use the plastic opening tool around the edges to loosen the battery.
    • Once the battery is loose, carefully lift from the bottom edge and remove the battery.
  7. Motorola Atrix HD  Touchscreen and LCD Replacement: 7 단계, 이미지 1개 중 1개
    • The battery may now be removed.
  8. Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: 8 단계, 이미지 3개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: 8 단계, 이미지 3개 중 2개 Motorola Atrix HD  Touchscreen and LCD Replacement, Rear Chassis: 8 단계, 이미지 3개 중 3개
    • Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
    • The adhesive strips may stay on the back cover or the battery.
  9. Motorola Atrix HD  Touchscreen and LCD Replacement: 9 단계, 이미지 2개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 9 단계, 이미지 2개 중 2개
    • The back case portion may be removed after the battery has been removed.
    • Use the T5 Torx screwdriver to remove the 10 coarse-thread 5mm screws
  10. Motorola Atrix HD  Touchscreen and LCD Replacement: 10 단계, 이미지 3개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 10 단계, 이미지 3개 중 2개 Motorola Atrix HD  Touchscreen and LCD Replacement: 10 단계, 이미지 3개 중 3개
    • Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
    • Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
    • The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
  11. Motorola Atrix HD  Touchscreen and LCD Replacement, Touchscreen and LCD display: 11 단계, 이미지 2개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement, Touchscreen and LCD display: 11 단계, 이미지 2개 중 2개
    • Begin by removing the 10 Torx T5 motherboard baseplate screws
    • The back chassis can now be removed.
  12. Motorola Atrix HD  Touchscreen and LCD Replacement: 12 단계, 이미지 2개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the 10 Torx T5 screws, that hold the metal frame to the motherboard.
  13. Motorola Atrix HD  Touchscreen and LCD Replacement: 13 단계, 이미지 3개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 13 단계, 이미지 3개 중 2개 Motorola Atrix HD  Touchscreen and LCD Replacement: 13 단계, 이미지 3개 중 3개
    • After following the steps to access the motherboard, you are ready to remove the touchscreen and LCD display.
    • Use the plastic opening tool to separate the LCD display from the motherboard.
    • The touchscreen may separate from the LCD, however they are both connected to the motherboard as one unit.
  14. Motorola Atrix HD  Touchscreen and LCD Replacement: 14 단계, 이미지 3개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 14 단계, 이미지 3개 중 2개 Motorola Atrix HD  Touchscreen and LCD Replacement: 14 단계, 이미지 3개 중 3개
    • Remove the ribbon cable from the back of the lcd using the plastic opening tool or spudger.
    • Use care removing the ribbon cables. They are very thin and are broken easily.
  15. Motorola Atrix HD  Touchscreen and LCD Replacement: 15 단계, 이미지 2개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the ribbon cable connecting the LCD display to the motherboard, be mindful that the ribbon cable is very thin.
    • With the LCD display removed, remove the ribbon cable connecting the touchscreen to the motherboard
  16. Motorola Atrix HD  Touchscreen and LCD Replacement: 16 단계, 이미지 2개 중 1개 Motorola Atrix HD  Touchscreen and LCD Replacement: 16 단계, 이미지 2개 중 2개
    • The LCD display and the touchscreen may now be replaced.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Gabriel Agaman
회원 가입일: 10/28/15
597 평판
안내서 3개를 작성함
UMass Dartmouth, Team 1-8, Miles Fall 2015 UMass Dartmouth, Team 1-8, Miles Fall 2015 회원
UMASSD-MILES-F15S1G8
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 1,149
