소개
The rear chassis of the phone is constructed of plastic which if dropped or subject to other impacts can crack or chip. It also houses the loud speaker. If you have damage to either of these components, this guide will show you how to replace them
필요한 것
Begin by removing the back cover using the plastic opening tool. There are adhesive strips attached to the back cover, so take care when prying case to prevent cracking
The adhesive strips may stay on the back cover or the battery.
Now with the screws removed, use the plastic opening tool to lift the edges of the front assembly.
Continue to use the plastic opening tool around the edges of the device to remove the front assembly.
The speaker is located in the upper corner of the case. It it attached with adhesive and can be removed by gently prying with the plastic opening tool
다른 2명이 해당 안내서를 완성하였습니다.
