주요 콘텐츠로 건너뛰기
Motorola Buzz ic502 Keypad Replacement
필요한 것
  1. Motorola Buzz ic502 Keypad Replacement, Battery: 1 단계, 이미지 1/3 Motorola Buzz ic502 Keypad Replacement, Battery: 1 단계, 이미지 2/3 Motorola Buzz ic502 Keypad Replacement, Battery: 1 단계, 이미지 3/3
    • First flip the phone over.
    • Then find the back release circled in red.
  2. Motorola Buzz ic502 Keypad Replacement: 2 단계, 이미지 1/2 Motorola Buzz ic502 Keypad Replacement: 2 단계, 이미지 2/2
    • Carefully remove the back using the release.
    • Lift from the bottom!
  3. Motorola Buzz ic502 Keypad Replacement: 3 단계, 이미지 1/3 Motorola Buzz ic502 Keypad Replacement: 3 단계, 이미지 2/3 Motorola Buzz ic502 Keypad Replacement: 3 단계, 이미지 3/3
    • Lift the battery from the right side.
    • After the battery has lifted about a 45 degree angle remove from phone.
  4. Motorola Buzz ic502 Keypad Replacement, Keypad: 4 단계, 이미지 1/2 Motorola Buzz ic502 Keypad Replacement, Keypad: 4 단계, 이미지 2/2
    • Remove the plastic pieces with metal spudge
    • Under both are two screws, remove those as well.
    • Remove the other four screws on back of phone.
  5. Motorola Buzz ic502 Keypad Replacement: 5 단계, 이미지 1/1
    • Carefully lift screen as to not snap wire that connects it (shown is a version in which the screen has been fully removed).
    • Lift off keypad and replace.
결론
Austin Quinn
회원 가입일: 10/20/16
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 6-6, Martin Fall 2016 UMass Dartmouth, Team 6-6, Martin Fall 2016 회원
UMASSD-MARTIN-F16S6G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 94
