주요 콘텐츠로 건너뛰기
Motorola C168 Front Panel Replacement
필요한 것
  1. Motorola C168 Front Panel Replacement, Battery: 1 단계, 이미지 1/2 Motorola C168 Front Panel Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Front Panel Replacement: 2 단계, 이미지 1/2 Motorola C168 Front Panel Replacement: 2 단계, 이미지 2/2
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Front Panel Replacement, SIM Card: 3 단계, 이미지 1/2 Motorola C168 Front Panel Replacement, SIM Card: 3 단계, 이미지 2/2
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Front Panel Replacement, Front Panel: 4 단계, 이미지 1/2 Motorola C168 Front Panel Replacement, Front Panel: 4 단계, 이미지 2/2
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Front Panel Replacement: 5 단계, 이미지 1/2 Motorola C168 Front Panel Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $3.99
    구매
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Wu
회원 가입일: 04/17/12
37 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-40, Regan Spring 2012 Cal Poly, Team 12-40, Regan Spring 2012 회원
CPSU-REGAN-S12S12G40
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,019
