주요 콘텐츠로 건너뛰기
Motorola C168 Screen Replacement
필요한 것
  1. Motorola C168 Screen Replacement, Battery: 1 단계, 이미지 1/2 Motorola C168 Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the phone so its back is facing you.
    • Press the release button on the back cover, while simultaneously pulling the cover down.
    • Remove the back cover.
  2. Motorola C168 Screen Replacement: 2 단계, 이미지 1/2 Motorola C168 Screen Replacement: 2 단계, 이미지 2/2
    • Pinch the sides of the bottom of the battery and pull upward.
  3. Motorola C168 Screen Replacement, SIM Card: 3 단계, 이미지 1/2 Motorola C168 Screen Replacement, SIM Card: 3 단계, 이미지 2/2
    • Press and slide the SIM card down.
    • Remove the SIM card.
  4. Motorola C168 Screen Replacement, Front Panel: 4 단계, 이미지 1/2 Motorola C168 Screen Replacement, Front Panel: 4 단계, 이미지 2/2
    • Orient the phone so its back is facing you.
    • Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
    • Note: If you are using iFixit's screwdriver toolkit, look for the smallest T-screwbit.
  5. Motorola C168 Screen Replacement: 5 단계, 이미지 1/2 Motorola C168 Screen Replacement: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $3.99
    구매
    • Lodge a spudger in between the front panel and the main frame of the phone.
    • Using a good amount of torque, pry the front panel from the phone.
  6. Motorola C168 Screen Replacement, Screen: 6 단계, 이미지 1/2 Motorola C168 Screen Replacement, Screen: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Spudger
    $3.99
    구매
    • Place the phone on its back.
    • Insert the spudger at the bottom of the phone, between the phone's frame and the circuit board.
    • Remove the circuit board from the frame.
    • Removing the board takes more force than you would expect.
  7. Motorola C168 Screen Replacement: 7 단계, 이미지 1/2 Motorola C168 Screen Replacement: 7 단계, 이미지 2/2
    • Bend the screen clamps outward so they are no longer underneath the circuit board.
    • Pull the screen encasing away from the circuit board.
    • Caution: The screen-to-phone interface will still be connected.
  8. Motorola C168 Screen Replacement: 8 단계, 이미지 1/2 Motorola C168 Screen Replacement: 8 단계, 이미지 2/2
    • Unplug the screen-to-phone interface.
    • Remove the screen from its encasing by pushing it out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Wu
회원 가입일: 04/17/12
37 평판
안내서 3개 작성하였습니다
Cal Poly, Team 12-40, Regan Spring 2012 Cal Poly, Team 12-40, Regan Spring 2012 회원
CPSU-REGAN-S12S12G40
4 회원들
안내서 8개 작성하였습니다
댓글 2개
motorola c168 network not working problem. how to repair network problem?
sattar - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 1,363
