이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the phone so its back is facing you.
Press the release button on the back cover, while simultaneously pulling the cover down.
Remove the back cover.
Orient the phone so its back is facing you.
Using a Torx T-4 screwdriver, carefully remove the 4 screws located at the corners of the phone.
이 단계에 사용된 도구:Spudger$3.99-
Lodge a spudger in between the front panel and the main frame of the phone.
Using a good amount of torque, pry the front panel from the phone.
Place the phone on its back.
Insert the spudger at the bottom of the phone, between the phone's frame and the circuit board.
Remove the circuit board from the frame.
Bend the screen clamps outward so they are no longer underneath the circuit board.
Pull the screen encasing away from the circuit board.
Unplug the screen-to-phone interface.
Remove the screen from its encasing by pushing it out.
다른 한 분이 해당 안내서를 완성하였습니다.
