주요 콘텐츠로 건너뛰기
Motorola C290 Antenna Replacement
  1. Motorola C290 Antenna Replacement, Battery: 1 단계, 이미지 1/2 Motorola C290 Antenna Replacement, Battery: 1 단계, 이미지 2/2
    • Position Motorola C290 so that the back of the phone is facing up.
    • Apply pressure to the back cover while simultaneously sliding it downwards.
    • Note: It may be easiest to apply pressure to the ridges at the top of the back cover.
  2. Motorola C290 Antenna Replacement: 2 단계, 이미지 1/2 Motorola C290 Antenna Replacement: 2 단계, 이미지 2/2
    • Place your finger in the notch at the top of the battery.
    • Gently lift and pull out battery.
  3. Motorola C290 Antenna Replacement, Antenna: 3 단계, 이미지 1/3 Motorola C290 Antenna Replacement, Antenna: 3 단계, 이미지 2/3 Motorola C290 Antenna Replacement, Antenna: 3 단계, 이미지 3/3
    • Unscrew antenna head from top of phone by twisting counterclockwise.
    • Pull the antenna out through the top hole and set aside.
  4. Motorola C290 Antenna Replacement: 4 단계, 이미지 1/2 Motorola C290 Antenna Replacement: 4 단계, 이미지 2/2
    • Remove the plastic tube by lifting the bottom and pulling out towards yourself.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Angelo Ballungay
회원 가입일: 04/15/10
79 평판
안내서 4개 작성하였습니다
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 회원
CPSU-REGAN-S10S24G28
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 1,999
