주요 콘텐츠로 건너뛰기
Motorola C290 Screen Replacement
필요한 것
  1. Motorola C290 Screen Replacement, Outside Case removal: 1 단계, 이미지 1/3 Motorola C290 Screen Replacement, Outside Case removal: 1 단계, 이미지 2/3 Motorola C290 Screen Replacement, Outside Case removal: 1 단계, 이미지 3/3
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Motorola C290 Screen Replacement, Removing the front casing: 2 단계, 이미지 1/2 Motorola C290 Screen Replacement, Removing the front casing: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Motorola C290 Screen Replacement, Disconnect the motherboard: 3 단계, 이미지 1/2 Motorola C290 Screen Replacement, Disconnect the motherboard: 3 단계, 이미지 2/2
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  4. Motorola C290 Screen Replacement, Removing the motherboard/screen: 4 단계, 이미지 1/3 Motorola C290 Screen Replacement, Removing the motherboard/screen: 4 단계, 이미지 2/3 Motorola C290 Screen Replacement, Removing the motherboard/screen: 4 단계, 이미지 3/3
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
결론
Angelo Ballungay
회원 가입일: 04/15/10
79 평판
안내서 4개 작성하였습니다
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 회원
CPSU-REGAN-S10S24G28
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 1,771
