주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This guide gives step-by-step instructions on repairing the speaker for a Motorola C290 cell phone.
  1. Flip open your Motorola C290. Remove rubber stoppers located around main screen using a push pin. This reveals four screws.
    • Flip open your Motorola C290.
    • Remove rubber stoppers located around main screen using a push pin.
    • This reveals four screws.
    • Use a Torx T6 Screwdriver to unscrew the four screws.
  2. Use a plastic opening tool to pry open a gap between the top cover and the face of the phone. Slide the plastic opening tool along gap and pry open case.
    • Use a plastic opening tool to pry open a gap between the top cover and the face of the phone.
    • Slide the plastic opening tool along gap and pry open case.
    • Remove top cover.
  3. Nintendo Switch 수리 키트
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Unclip circuit attachments located on back of screen circuit board using a Spudger. Unclip circuit attachments located on back of screen circuit board using a Spudger.
    • Unclip circuit attachments located on back of screen circuit board using a Spudger.
  5. Insert the plastic opening tool between the metal screen components and the plastic frame at the corners. Firmly pry the screen components from the frame with a twisting motion You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Insert the plastic opening tool between the metal screen components and the plastic frame at the corners.
    • Firmly pry the screen components from the frame with a twisting motion
    • You will need to apply a good amount of force as you pry, twisting in a right-to-left motion.
    • Completely remove screen components from frame.
  6. Insert spudger underneath the speaker. Gently break the sticky seal between the phone case and speaker. Lift the speaker off the phone case.
    • Insert spudger underneath the speaker.
    • Gently break the sticky seal between the phone case and speaker.
    • Lift the speaker off the phone case.
    • Note: It will be necessary to destroy the seal to remove the speaker.
결론
Philip Ybarra
회원 가입일: 2010년 04월 15일
18 평판
안내서 1개 작성함
Cal Poly, Team 24-28, Regan Spring 2010 Cal Poly, Team 24-28, Regan Spring 2010 회원
CPSU-REGAN-S10S24G28
4 회원들
안내서 6개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,092
