소개
Use this guide to replace the LCD in your Motorola C350.
부품
지정된 부품이 없습니다.
slide the black button to free the battery so you can grab it with your other hand.
You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
